20 Most Recent Dell UltraSharp 2001FP 20.1" LCD Monitor Questions & Answers
2answers
BLACK LINE on screen and see-through Pink Bar!
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
12/1/2014 1:54:24 AM • Dell UltraSharp... • Answered on Dec 01, 2014
Monitor led turn yellow
Try resetting the video cable or replace it.
6/9/2014 9:54:58 AM • Dell UltraSharp... • Answered on Jun 09, 2014
Half of the Dell 2100FP screen is color bars???
Please specify this happened after which event ,e.g. like when you connected another device or installed a game
10/16/2013 6:53:27 AM • Dell UltraSharp... • Answered on Oct 16, 2013
0answers
2answers
Pink Stripe
I must say thanx to Bogdan, his suggestion really did helped to fix my Dell :D
Only, the hard part was the opening of the case, it has no screws saide the middle behind the holder, but just hidden plastic border pins like on average cheap plastic remote control. After that, and removing few tin shells, second plastic connector ribbon from 10 of them needed a little press by nail and this is it! Thanx again :) I must point out that 2 local dell services said that lcd is unrepairable?!?! But shure, they did not bother to even open the case, or else, I would see the opening marks on plastic.
6/28/2013 1:57:52 PM • Dell UltraSharp... • Answered on Jun 28, 2013
Vertical color lines from top
Two possibilities from my experience: bad LCD panel or bad DC feeding the LCD panel (you need to use meter and scope to look for bad AC ripple on the 5vdc or 12vdc feeding the panel).
See example here; http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: www.interliquidparts.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
8/14/2011 11:27:04 PM • Dell UltraSharp... • Answered on Aug 14, 2011
4answers
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
5/17/2011 11:07:28 AM • Dell UltraSharp... • Answered on May 17, 2011
Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
4/11/2011 4:43:12 PM • Dell UltraSharp... • Answered on Apr 11, 2011
I have 2 inch wide
Seems to be a problem of LCD panel? Cannot be cost effectively repaired. Samir
2/17/2011 9:36:42 AM • Dell UltraSharp... • Answered on Feb 17, 2011
This monitor uses a power supply not just a cord . You can get one on e-bay very cheat . Just type out 2001fp an choose the person you want to get it from .
2/11/2011 6:14:44 AM • Dell UltraSharp... • Answered on Feb 11, 2011
Dell Monitor 2001FP has a
They are on e-bay for very little . Just type in 2001fp an you will get people who have new power supply .
2/9/2011 4:21:52 AM • Dell UltraSharp... • Answered on Feb 09, 2011
Dell 2001 fp monitor has
This not good! the problem is in the LCD panel display, and there is no way to repair this on a practical scale, this would not be a cost effective repair, far cheaper to replace the monitor.
2/7/2011 12:49:32 AM • Dell UltraSharp... • Answered on Feb 07, 2011
After been on for a while it start getting some
You have failing LCD panel, and it will get worst, it will have more lines as more circuits in the panel starts failing.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/6/2011 10:10:12 PM • Dell UltraSharp... • Answered on Feb 06, 2011
Solid bar down left side
The problem is very likely at the LCD panel, you must go into service.
2/3/2011 7:04:39 PM • Dell UltraSharp... • Answered on Feb 03, 2011
Suffering from EXACT same problem. Also Dell UltraSharp 2001FP
This is heat, and is a common problem; it affects two of mine. You can verify this by having a can of Dustoff available and catching it when it first starts. Blow in at the top of the monitor through the holes in the back in the same region as the band. The color aberration should go away.
My solution was to make a shroud from black foamcore and use a spare power supply fan to blow air into the case at the top. This has worked for my two monitors for about 18 months. You can also just buy a 12v computer cooling fan for this purpose.Should be somewhere around 75mm in size and quiet, 'cuz you'll be putting up with it if it's not.You can either get a general 12v power supply, or an adapter that fits the 12v power out at the back next to the USB input connector.
1/26/2011 5:55:02 AM • Dell UltraSharp... • Answered on Jan 26, 2011
I have a dell 2001fp. it is locked and can not
When you change to VGA, you have to change cables to a D-SUB cable. If you want to use S-VIdeo, you have to use an S-Video cable. You could actually have four different devices using the four different cables connected to the monitor one time, and change which one you are looking at by suing the button on the front panel to select the appropriate input.
1/26/2011 5:49:17 AM • Dell UltraSharp... • Answered on Jan 26, 2011
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
109 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
UltraSharp Dell
  • UltraSharp Dell
Most Popular Question
dell monitor 2001fp
  • Computers & Internet
