20 Most Recent
Cyber Acoustics CA-2016 Computer Speakers Questions & Answers
Distorted speaker sound
It might be that you have a bad solder joint somewhere. Try shaking the speaker when playing, but be careful not to short the speaker wire connections. If it returns to normal at any point this is a dry joint somewhere.
I have a dell pc in a docking station. I am using
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
I cant install them?
The CA-2016 desktop 2-piece system it is a USB powered amplifier that draws the power through a USB cable. No batteries or AC power source/wires are required which leaves the desk top clean. The speaker system is magnetically shielded and has a LED power indicator. This being said setup the speakers plug in the USB cable, notice if the LED power indictor light is on. Adjust volume control on speakers and on your computer ( make sure your not muted ). PC's have a lot of different media players that can and will effect the volume control so if one or more of those items are adjusted to low volume or muted, there will be little to no output to your speakers.
Computer speaker installation
I may have disconnected them and I need the disc to download so they will work- they worked earlier today and now they do not
Computer Speakers
Try and plug your speakers into a friend's computer and check if they work. If they don't, then the speakers are fried, probably because of a voltage surge when the power went out. If they do work on your friend's computer then you most likely have a bad port on your computer because of the power surge.
Why does my sub woofer not work
it could be a connection from not grounded to your aux cords being crimped and messed up could be amp or could be a setting on your radio..
Cyber Acoustics CA-3618 subwoofer cuts in and out.
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
