20 Most Recent
Sony Handycam CCD-TRV416 8mm Analog Camcorder Questions & Answers
HANDYCAM USE
Go to any Sony dealer ask for NP-33 battery pack for your CAM
Cheers
Picture rolling
the problem of your camera is the alignment...so try to adjust the two tape guide and two small screw near at the video head is you can open your camera..doing these you should be careful cause your to close to the head or you may damage it..adjust the small screw first slowly...if is not work then the tape guide...
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
