20 Most Recent
JVC GR-SXM750 S-VHS-C Analog Camcorder Questions & Answers
I have a DVD Burner how can I burn a copy of a
One way is to capture it to your computer and then make a DVD out of it using a video NLE (non-linear editor)... if you are running XP/Vista/7 you can use Windows Movie Maker(r). It has enough basic functionallity to do what you want. more middle of the road NLEs incluse Corel, Pinacle and my favorite Sony Vegas
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
