20 Most Recent Sony Handycam DCR-PC110 Mini DV Digital Camcorder Questions & Answers
I have a DCR-PC110 that was dropped.
Yes. It's broken.
12/1/2017 10:43:35 PM • Sony Handycam... • Answered on Dec 01, 2017
My Sony PCR PC110 camcorder
Sounds as if it is failing - time for a replacement
9/28/2017 9:37:21 AM • Sony Handycam... • Answered on Sep 28, 2017
Cassette stuck / wont eject from sony handcam DCR PC110
shut it off and than back on. check battery, if that don't work your motor is going out, needs to be service.
3/9/2017 9:38:22 PM • Sony Handycam... • Answered on Mar 09, 2017
2answers
When I turn onto the
That error means that something is out of alignment or stuck in the tape mechanism. You have two options: to have the camera inspected and repaired, OR if you don't want to do that and feel you don't have anything to lose do this:
Remove the tape.
Close the tape door completely.
Close the LCD.
Turn the camera off.
Remove the battery.
Give the camera a good firm smack or two on each side with the palm of your hand.
Power the camera up and try the tape again.
It sounds crazy, but doing that can possibly help unjam whatever mechanism is locked up.
This has worked for many people.
Hopefully it will take care of your situation too.
2/28/2013 5:53:14 PM • Sony Handycam... • Answered on Feb 28, 2013
2answers
Sound recording not working
Try to set the "VCR Set" in the middle of the bar
1/20/2013 7:17:52 PM • Sony Handycam... • Answered on Jan 20, 2013
3answers
Sony DCR PC110e camcorder
My problem with the DCR PC110E Sony camcorder is being unable to download my videos from tape to the PC or laptop through the firewire connector. Have you ever had this problem?
1/20/2013 7:15:14 PM • Sony Handycam... • Answered on Jan 20, 2013
I need an owners manual
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
2/13/2011 3:00:22 PM • Sony Handycam... • Answered on Feb 13, 2011
How to transfer minidv video to computer?
Ensure you have been installed picture motion browser ( sony handycam sotfware) on your computer. Connect your handycam to PC using (supplied) usb cable. You will find new hardware pop up. Just click and follow instructions. In you can not find connection, run explore and find your files to transfer and copy. Done You can now re-produce your AV to other media. Regards,
12/8/2010 8:12:16 PM • Sony Handycam... • Answered on Dec 08, 2010
I am getting solid horizontal lines on my screen -
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/19/2010 7:01:41 PM • Sony Handycam... • Answered on Sep 19, 2010
I have a handycam DCR-HC18e. The nightshot plus
This has jammed, remove recording tape and perform reset.
7/3/2010 1:02:31 PM • Sony Handycam... • Answered on Jul 03, 2010
Charged batteries not working
Having too batteries rules out that problem of being flat, this sounds like a charger or plug fault so grab a new charger and see if that works.
5/28/2010 2:27:19 PM • Sony Handycam... • Answered on May 28, 2010
Sony DCR-PC110E - can I charge the battery through USB?
no man u can"t....in all sony brands the mini usb is meant only for data transfer...so better you go for a an ac power adopter...mail me at [email protected]
9/20/2009 11:17:00 AM • Sony Handycam... • Answered on Sep 20, 2009
Can't upload to my laptop!
Option 1:
If you want to use the USB cable to connect the Camera to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Your Camcorder does not supports a Wireless MIC. However, you can use a MIC with your Camcorder using the available Accessories Shoe port.
Good Luck!!!!!!!!!!!!!!!
9/18/2009 7:29:40 AM • Sony Handycam... • Answered on Sep 18, 2009
I have a sony dcr-pc110. how can i see it on my
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
You can use the Movie maker to burn it to the Disk
3/10/2009 3:28:06 AM • Sony Handycam... • Answered on Mar 10, 2009
Sony DCRA-C162 Camcorder. I need a replacement battery for the DCRA-C162. Does anyone know where I can get one?
Question edited for clarity, add full 'make model (what it is)'. Question moved from Cars and Trucks category. Searching for your manual keeps bringing up this manual https://www.sony.com/electronics/support/res/manuals/2698/26988801M.pdf Looking at that manual Page 16, it states the battery pack as 'NP-FP50', and that turns up batteries for $15. https://www.google.com/search?q=NP-FP50 ..
11/20/2023 12:02:19 AM • Sony Handycam... • Answered on Nov 20, 2023
Sony Handycam CCD-TRV68 Flashing No Tape and Eject Symbol
If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test. Probably too old being 2001 vintage.
11/19/2023 12:20:58 AM • Sony Handycam... • Answered on Nov 19, 2023
SONY mini HandyCam model V569. HOW DO YOU TURN ON A SONY V569?
Question edited to add full model designation. Question moved from Sony Computers. This doesn't seem to be a very well known model. It is not even listed on their website. https://www.sony.ca/en/electronics/support/cameras-camcorders/manuals/results?query=V569# There are normally two batteries, a small one that just saves memory and runs the operating system, and a larger battery that actually powers the camera. Try contacting Sony direct There is a bit of help here, but not enough. https://www.google.com/search?q=SONY+V569 ..
8/4/2023 4:37:50 AM • Sony Handycam... • Answered on Aug 04, 2023
Sony Handycam DCR-PC110 Mini DV Digital Camcorder Logo
27 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
when turn onto
  • Video Cameras
