20 Most Recent JVC GR-HD1 Mini DV Digital Camcorder Questions & Answers
2answers
I need to replace the CCD in a JVC GR-HD1U camera.
http://www.manualsparadise.com/ShowProductsForModel.do?model=M88219169
These are impossible to find free on the net but it's not a bad price if you are doing this repair yourself and saving hundreds.
5/26/2019 10:54:16 AM • JVC GR-HD1 Mini... • Answered on May 26, 2019
2answers
Power Button Came Off
Hopefully this is not a duplicate post as I lost the previose post I spent so long writing when I hit Post Solution.
I had the same issue with mine and finally lost the button. I could not find a way to get it to stay in (and I'm very good a figuring things out like that). I'm pretty sure something broke and left no sign.
I called JVC when it happened back in 2007 but there was no recall on this. The tech I talked to could not find the part and told me it was not available. Two years later I decided to try again and this time talked to a tech lady that was very open about how and what she was looking at to find the part. When she could not find it, she emailed me a parts diagram (exploded view) of every component set that makes up the camera. Turns out that the switch is not mentioned anywhere in the parts list that correlates with the diagrams because it;s part of an assembly that has do be replaced as a whole. This is more info to back up my thinking that the switch can not be put back in place once it pops out. After we both looked at it for a while I found it as the exploded view is not showing that portion of the handle in full view. I forget the name of the assembly but I think it said something like Power(rec?) board IDK. Either way it sounded more of an internal thing but that was it. I will be ordering this part this year so I will have to dig up all that info again. The process to replace this switch assembly is very complex and requires that the handle/tape housing be removed from the camera. Then it all has to be taken apart with tons of micro screws and small parts. No unsoldering that I could see (most every mini board disconnects with mini plugs. Let me know if you want more info once I order this part. I think it was around $150 but I hope it is still available.
9/22/2016 8:12:25 PM • JVC GR-HD1 Mini... • Answered on Sep 22, 2016
0answers
JVC GR-HD1
Be the first to answer 9/24/2013 1:42:52 PM • JVC GR-HD1 Mini... • Posted on Sep 24, 2013Be the first to answer
If my JVC-GRHD1 won't record on an SD card which type of card do I need?
This camcorder will use SD cards. However it will not use SDHC cards such as your 16GB Lexar card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
5/20/2012 9:39:27 PM • JVC GR-HD1 Mini... • Answered on May 20, 2012
My JVC-GRHD1
5/20/2012 9:39:06 PM • JVC GR-HD1 Mini... • Answered on May 20, 2012
When I plug my jvc gr hd1u into my laptop to
Hi, forgive me if I'm telling you something you already know but if you shot video in DV mode then the iLink switch on the camera has to be set to DV. If you shot video in SD or HD mode then it must be set to MPEG2.
11/18/2011 5:36:04 AM • JVC GR-HD1 Mini... • Answered on Nov 18, 2011
JVC Gr HD1 power/record button fell off and tape stuck inside
I have a solution posted on replacing the button in another Question but as far as your question; If you still have the button you can pop it back in (push in and hold tight) and move it to the position to turn it on. Once it's on you don't have to hold it in to keep the camera on. Only switching it to the off position will turn it off. Let me know if you lost the button and I can give you a work around for that (even if you still have the button and are jamming it in there but it's not working my workaround could help).
11/18/2011 5:23:24 AM • JVC GR-HD1 Mini... • Answered on Nov 18, 2011
Just bought a used JVC
This camera can not use an SD card of that size. Just like with any computer intergraded hardware, they have to write parameters of that day into the operating system of the device. They can not just leave it "open ended" to allow any size that might be available in the future. I believe the maximum is 1GB of standard SD speed (as in not the max of ultra speeds). 1GB would be more than enough at the resolution this camera will store still frames (it can not store video on SD cards). This is from personal experience with my own GR-HD1U.
9/4/2011 10:56:29 PM • JVC GR-HD1 Mini... • Answered on Sep 04, 2011
2answers
The camera will not let me record video with the
The sd card is only for static pictures.
only a 16meg card supplied with the camera.
3/16/2011 3:58:39 PM • JVC GR-HD1 Mini... • Answered on Mar 16, 2011
I CANT GET THE JVC
Try the ensharpendecoder-win.exe by techsmith from camtasia studio 7.
I have been having problems for 2 years with Studio 11 plus and my GR-HD1.
And yesterday i downloaded this small prog 353 kb and now i can use the camera in Mpg2 mode.
Hope this helps anyone with the same problem
Regards Barry
3/16/2011 3:51:57 PM • JVC GR-HD1 Mini... • Answered on Mar 16, 2011
How much for this camera on this days ????
That particular camera easy can go from $1,200 - $1,500 and some with very little accessories.
1/12/2011 3:46:35 AM • JVC GR-HD1 Mini... • Answered on Jan 12, 2011
How do you get the JVC GR HD1 to upload in hd on a
This can be done through the fire wire port (mini firewire400 on the cam to what ever firewire size port is on your computer) to and any video editing software that can handle HD codecs. Inside the editing software there will be a way to import video from a camera. This part of the program will control the start and stop of the camera via the firewire (ie you do not push buttons on the camera). It will start the tape and record into the PC. You can choose to compress the video to a bunch of different formats to make it more manageable. The owners manual spells it out pretty good. If you can't find it let me know and I might still have a web link to one.
10/14/2010 2:17:06 AM • JVC GR-HD1 Mini... • Answered on Oct 14, 2010
I cant get my JVC GR-HD1US camcorder which records
Did you ever get this to work? I have the same camera (but on a Mac). On a Mac you have to set the capture to the correct setting (ie. the way it was recorded on camera). The frames per second and resolution have to match. When on DV setting the camera converts the video to DV standard and all consumer editing programs can import that with ease (almost no user setup). I'm sure you have the right switches and settings on the camera (being that you own this and most likely know how to use it). Those setting should be in your manual. If you can not set the capture setting in the editing programs then you will need a more powerful editing program.
6/2/2010 4:44:29 PM • JVC GR-HD1 Mini... • Answered on Jun 02, 2010
JVC GR-HDKR1 digital camera compatibility issue with MAC
Just output via the AV jacks, and use a TV/Video input card or USB dongle. You can then Play the DVR, and Record on the PC, With Video Recording Software, through the Video Input. On your chosen device. You can get Component, or Composite Video IN. Audio is in Stereo. Then you will be able to be able to use your camera again... ?
3/30/2010 9:00:17 AM • JVC GR-HD1 Mini... • Answered on Mar 30, 2010
JVC GR-HD1 Mini DV Digital Camcorder Logo
Popular Tags
31 questions posted
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
jvc grhd1 won 39 t record sd card type
  • Video Cameras
