20 Most Recent
Sony Handycam CCD-TRV37 Camcorder Questions & Answers
Icon
The icon you see is "EJECT" tape. It shows there is a problem with unit but cannot be defined without having unit checked by a pro tech
Handy cam video 8 XR keeps ejecting cassette any
thats is because the servo mechanism chip do not detect the cassette,
when its in the housing could be a sensor or the cassette in switch or mechanism its self (missalignement.)
hope that will help you
regards alan.
No funciona pausa play rew stop ff
Hi Marco, I am from Spain, I tried to write in Spanish but the system does not allow that.
I have the same problem. Have you the solution? I saw nobody answered you in two years.
regards from Alicante.
Alex
Error code c:21:00
it means your camera is detecting moisture that why c21:00 is appearing then try to warm the camera using a hair blower you should open the lid
cover of the mechanical.......... turns off the camera and unplugged
the ac adaptor..if you using the battery take it out ... then place
your hand to the mechanical to sense the heat of the camera when you
using the hair blower and when you feel too hot then stop the
blower.... doing this must not exceed 10 second...... then wait at
least 1 minute to cold down the camera and put the adaptor or the
battery then power on the camera.... if you doing this and nothing
happen....i suggest you to go to the service center for replacing the
dew sensor....
Hi8 Video to DVD
CCD-TRV37 is analog video camcorder and can not be hooked directly with computer because camcorder video-audio out is analog and computer needs digital format.
You can hook camcorder with DVD Recorder and burn a DVD. Now you have data in digital format and can transfer in your computer.
How do i connect to tv for replay
Connect the Camcorder to the TV using A/V cable. Yellow, Red and White combination on the TV side. Probably a single connector in the Camcorder side. Once you make the connection, switch on the Camcorder in playback mode and play the recordings. Select input using the input button on the TV. Please let me know if you require any further assistance.
