20 Most Recent Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Questions & Answers
It is unlikely that the 'latest' drivers will work with an unsupported OS like XP
Sony Handycam... | Answered on Nov 05, 2017
when I opened up the camera, the tape part of the cassette was hanging out. I tightened the tape and reinserted the cassette. this seems to have fixed the problem. hope this helps.
Sony Handycam... | Answered on Oct 06, 2014
where are you from? I don't have it. but i know a place nearby to get it.
Sony Handycam... | Answered on Nov 03, 2012
Thank for that qestion,
At this point, if you are a lay-man or person you need to eject the camcorder and aloud it open and put under sun light for an hour. If its do the same, take it to a technicain.
but if you are a technicain, dismantle the camcorder and put the machinusm under hot tempreture for 20minute. then mount it back and your camcorder will be fine.
I have done this time and again and it has never fail me.
I hope you will smile.
Sony Handycam... | Answered on Oct 01, 2012
did this some time ago so i don't recall clear...
-download the XP driver from the website
-create a folder on the c drive and run it from inside this folder - it will decompress the files to a folder called Sony_usb
-run setup from the Sony_usb folder - install in compatible mode after warnings
-restart pc
-open device manager -right click on the icon with the question mark and select Update driver
-browse to the location of the Sony_usb folder
-you will receive x red message (don't recall what the warning was) click ok and another message will pop about compatilbel install - do the compatible install.
to sume up - do xp compatible install all across
hope this helps
Sony Handycam... | Answered on Aug 10, 2012
The only suggestion I can give you is contact Sony to see if they can provide you with an updated driver for windows 7 to allow your handycam to work with your computer. Unfortunately when windows changed their operational systems a lot of companies did not offer the required driver upgrade for people that have older units, and even if you went with the Firewire I think you would still run into problems with compatibility issues.
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
Sony Handycam... | Answered on May 26, 2012
I assume that you are running Windows XP in your PC and have Sony DCR-TRV19 camcorder.
Please go to camera Menu and enable USB stream option. Computer will recognize camcorder.
If any thing is different, let me know to help you out.
Sony Handycam... | Answered on Mar 16, 2012
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
148 questions posted
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
lcd sony digital video camera recorder
  • Video Cameras
