20 Most Recent
Sony Dvcam DSR-PD100 Camcorder Questions & Answers
Volume control
can u check .Is there audio output from the headphone out.
If there is then there is a problem with ur small speaker at left side of camera near to LCD disply
How to change internal battery pd100
I have the same problem. It looks to me like the "coin" battery (which has solder tags) is soldered to a pcb inside the camera.If anyone has information as to the battery details (voltage, size, etc.) and how to access it with the minimum of dismantling, it would very helpful. I think sony reference a BT7200 battery but I can't find details anywhere.
Mini tape holder keeps opening
Sounds like a little sand and / or moisture made it's way into the camera. A call to the Sony Company Tech Support will let you know if one of the canned compressed air cleaners for computers would be advisable.
Another thought is to check if there is something in or near the hinge of the tape hatch apparatus. Sometimes I take one of those electronics foam "Q-Tips" and wipe out the area in case a piece of dust or fuzz or something is causing a malfunction.
I have just connected my
switch off then on the power of the camera, make sure the camera is in vcr playback mode
check if the camera is compatible with windows 7
go to your cameras website and download latest drivers
Computer wont recognize DsR-pd100
didn't you get a driver disc?...
Please don't forget to rate me "FIXYA"...thank you!
Cannot playback minidv in VTR mode with pd100
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sound dropout
hi,
the problem could be because of the problem with the pinch roller ,either it has some wear or the supporting spindle needle has some improper orientation.
Is this with a specific tape or all tapes?
if it is specific to a tape then it can be because you kept the recorded tape near magnet which causes this rythmic sound drop out.
i guess the first one may be mostly happened.
all the best
sreejith
Sony DCR IP1E screen black
Replacing the flex cable on a camcorder can be a delicate and complex process, as it requires disassembling the device and accessing its internal components. Here are some general steps that you can follow:
- Turn off the camcorder and remove the battery.
- Locate the screws or clips that hold the casing of the camcorder in place. Depending on the model, these may be on the bottom, sides, or back of the device.
- Carefully remove the casing and set it aside.
- Locate the flex cable that connects the LCD screen to the circuit board. It may be taped or clipped in place.
- Gently disconnect the flex cable from the circuit board and LCD screen. Take note of how it is connected so that you can reattach the new flex cable correctly.
- Install the new flex cable in the same position and orientation as the old one.
- Reconnect the flex cable to the circuit board and LCD screen.
- Replace the casing of the camcorder and secure it with screws or clips.
- Reinsert the battery and turn on the camcorder to test the LCD screen.
It's important to note that the specific steps and tools required for this process can vary depending on the make and model of your camcorder. Additionally, if you're not familiar with electronics repair, it's generally recommended to have a professional technician perform the repair to avoid damaging the device or injuring yourself.
I have a sony dcr-dvd108. Can I get some help?
It sounds like your Sony DCR-DVD108 camcorder may have a problem with the battery or the power connection.
For the battery issue, you can try replacing the battery with a new one that is compatible with your camcorder. The Sony NP-FP50 or NP-FP70 are compatible batteries for your DCR-DVD108. You can purchase them online or from a camera store.
As for the "Movie Disabled" message, it may be caused by the type of disc you are using. The Sony DCR-DVD108 camcorder is compatible with DVD-R and DVD-RW discs, but it may not be compatible with all brands of discs. You may need to try using a different brand of disc to see if that resolves the issue.
Additionally, make sure that the camcorder is set to the correct recording mode, such as video mode, and that there is enough space on the disc to record the video. If none of these solutions work, there may be a problem with the camcorder itself, and it may need to be repaired or replaced.
