20 Most Recent
Mag Innovision LT576s 15" Flat Panel LCD Monitor Questions & Answers
Won't work.
You have to press the fn+f5 I think in your laptop. It is the same when you are using a projector.
MAG innovision LT-926W 900W problem!
After
this means your power inverter inside the monitor is dead. This little gizmo lights up the monitor backlight. They dont fail all at once, but slowly die and give problems like you describe, you can order these online for your monitor , or find one on ebay for under 30 dollars, but unfortunately there is no fix, other than replacing the inverter.
sorry. Please use the thumbs up rating if you find my answer helpful, albeit bad news.
Take care.
Volume
sound does not come from the monitor it comes from the computer. try hooking your speakers up there
LT582s Mag Innovision
It all depends if the Mag has been used before on the same system or it is a new installation or on a different computer.
- If it is connected to an existing set-up and has been used previously, then possibly it is the computer's video card/memory or just not booting. Alternately, it could be the video interface/main board of the monitor or even possibly the cable;
- If it is just being installed on a known good computer, then it could be that the screen resolution and/or the screen refresh rate of the display properties of the computer needs to be lowered down.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Mag Innovision LT576S monitor goes blank after 2 seconds
I would think that the monitor is the issue, especialy that in safe mode it still does not function properly!
The fault with the monitor may be in the scan amplifier circuits, and or the power supply.
When I used to service these, I found many times that there were defective electrolytic capacitors in the scan amplifier sections and the power supply that gave problems.
This type of repair is time consuming, and when out of warranty it may not be worth the cost.
I would be seriously considering an LCD monitor.
Jerry G.
