20 Most Recent
Sony DCR-DVD301 DVD Camcorder Questions & Answers
The toggle button on my sony dcr-dvd301 doesn't
If you are handy with electronics stuff repair and can take apart camcorder then can replace toggle switch in Sony DCR-DVD103 camcorder, it is mounted on JS-031 board, its small circuit board that is easy to get replaced by taking off side cabinet. JS-031 board part number is as follows:
A1070102A ..... JS-031 BOARD, COMPLETE
Available in
PartStore.com for $37
Hope these info will help you.
Thanks.
When I turn on the camera I get a white screen on
It sounds video processor is not getting voltage from sub power supply section on main board of camcorder that is why you do not get any video output in lcd or viewfinder in any mode.
I'm Sony camcorder tech and can help you if you are handy with electronics stuff repair and can take apart camcorder easily with proper tools.
In my opinion, there would be fuse blow out that provides volts to video signal section. Let me know exact model number of camcorder to proceed and if you feel uncomfortable working on camcorder then local camera repair shop is an option to get it fixed.
Thanks.
Disc Read error
I do have the same problem. It all started when I started using Sony discs that has a label to write on one surface. Don't know how to fix it. It is now almost useless!
Raj
Focus issues
Scotty, this model has had issues with the focus stepper motor in the lens. I would call Sony customer service and ask them if there has been a service advisory issued for this model that addresses the slow focus issue.
Good Luck to you.
J. Weibel
CustomElectronics.Org
Dvd301 no power
needs to be sent in theres a prolem with the main pcb it happens alot. sorry
Transferring data from disc after finalization was interrupted
Yapp!! Playing the disc using your camera and records the output into another media is the best way to transfer your disc data. Computer nowaday has built in digital capture card, you can record your movie through firewire or IEEE1394 connection(unit always comes with these cables). You can even edit youyr movie, I suggest you learn adobe premiere softwares. Norton is only better when your disc is unreadable or corrupted( thats why he called it data recovery) [:0)
Power disconnected during finalization
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
How do I clean a Dyson DC 23 so it will pass quarantine inspection when moving overseas (to New Zealand)
you will to ontact the customs office in Kiwiland for that answer. In most cases cleaning the hopper in warm soapy water and buying new filters is enough. Some places require a hospital grade detergent such as wESCODYNE be used to include the air hose(s). Please beware, the AC power in AU/NZ is 230 VAC, so you will need a step down power transformer to use it there. (You'd be better off just buying a new one there to be honest, then you needed worry about lugging a heavy power transformer around of changing the plug end to the Clipsal type used in AU/NZ.)
