20 Most Recent LG Flatron L1710S 17" LCD Monitor Questions & Answers
3answers
Backlight goes off after 2 sec on LG L1710S LCD monitor
Your problem could also be bad capacitors, as this user found on his Flatron L1710S.
12/27/2014 3:42:52 PM • LG Flatron... • Answered on Dec 27, 2014
How to open a FLATRON L1718S LCD screen
Those screens are so inexpensive, it really isn't worth your time to try to repair them...Spend a buck and use your time for more important things!
1/2/2013 3:30:03 PM • LG Flatron... • Answered on Jan 02, 2013
All white screen
tried to replace the vga cable and fix the vga port doesn't work?.if still white screen the cause will be bad lcd controller.
10/28/2012 3:21:26 AM • LG Flatron... • Answered on Oct 28, 2012
2answers
My lg flatron l1710s flashes on and then the
This is highly suggestive of a power supply failure to deliver the voltages required. A new power pcb should fix the problem but is a job for an experienced repairer.
4/24/2012 1:33:57 PM • LG Flatron... • Answered on Apr 24, 2012
2answers
No image on screen when boot up computer
check vga cable! check also video card on the pc!
4/24/2012 1:33:13 PM • LG Flatron... • Answered on Apr 24, 2012
3answers
My flatron L1710S flat screen will not come out
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
4/24/2012 1:28:54 PM • LG Flatron... • Answered on Apr 24, 2012
When i'm on my tft it show the disply suddly sceren goes on dark .
That shows that your monitor has failing capacitors. Capacitors in a monitor are responsible for holding down the power from the supply so for a proper display on your monitor! What happens is that when you switch on your monitor, the capacitors hold power enough for a normal display on your monitor. This means there are failing capacitors in your monitor. The only solution to this is to replace bulged or burst capacitors. You can get a Computer Technician to do this for you or you can do it for yourself. Open up the monitor using a sharp flat tool (knife or anything like that) starting from the bottom, working your way round to the top. You will notice the finger-like plastic clips that hold up the two sides together. On the circuit board where the power supply is connected, that is where you are going to find the capacitors. Check for any bulged-head capacitor. Replace the capacitors with the same type of capacitors (for example 1000u 10v). Make sure when replacing it to note the plolarity (+ or -)
11/28/2011 8:45:57 AM • LG Flatron... • Answered on Nov 28, 2011
I have lg flatron 21inch tv in sreen white line
See my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
The fix for horizontal lines is the same as the fix for vertical lines.
Enjoy my tip
Slasher_X
7/10/2011 8:32:35 PM • LG Flatron... • Answered on Jul 10, 2011
I switch on my PC,
First of all check your VGA cable is working or not.
If VGA cable is ok than do the following steps.
  1. Turn off all peripheral devices connected to the computer.
  2. Disconnect the computer's power cord from the AC power source (wall outlet or power adapter).
  3. Remove the computer cover.
  4. Locate the battery on the board (see figure below).
  5. With a medium flat-bladed screwdriver, gently pry the battery free from its connector. Note the orientation of the "+" and "-" on the battery.
  6. Wait for 1 to 5min then re-place the battery back again.
  7. Re-place the computer cover.
  8. Plug the computer and all devices back in.
Second step you can do is
1) Remove the RAM from the RAM bank clean it properly and insert it back again.
If still you are facing the same problem ... you can Remove the CPU fan and put some cooling paste on top of CPU and re-place the FAN back.
7/6/2011 5:18:18 PM • LG Flatron... • Answered on Jul 06, 2011
2answers
When i switch on the computer, the only thing that
Im assuming the monitor worked OK until now. The two things I can think of is, First is the cable from the monitor to the computer is either not connected tight either on the monitor side or the computer. The second thing I can think of is a bad video card. I think the monitor is ok because your getting the power save mode on the screen.
I hope this helps you out, if it does please leave me some positive feedback.
4/4/2011 8:26:59 AM • LG Flatron... • Answered on Apr 04, 2011
My monitor LG flatron when
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/15/2011 3:48:11 PM • LG Flatron... • Answered on Feb 15, 2011
Power on power led blinking
Hello.
The LED blinking light usually means that the attached PC is not powered on or the VGA connector (end of cable connected from the monitor to the PC) on the monitor, the cable or the VGA port on the PC is faulty.
Try your monitor on another computer. If it works, there is a problem with your PC. If it doesn't work, the VGA connector, the monitor's VGA cable or the monitor itself, is faulty.
Hope this helps.
1/23/2011 3:04:08 PM • LG Flatron... • Answered on Jan 23, 2011
How to edit my pictures into the artist?
Open your Artist and select the image you want to edit.
12/1/2010 3:11:17 AM • LG Flatron... • Answered on Dec 01, 2010
I have a flatron L1710S monitor. It has no red
Check all the pins on the VGA cable first, also try it with another PC to make sure it is not the video card.
Please post back what you find.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
10/29/2010 2:23:13 AM • LG Flatron... • Answered on Oct 29, 2010
Hi i have a lg
i assume you dont have the manual for this LCD monitor ?
if not go here and download, then read the symp[toms for what your LCD is experiencing
http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=L1710S&initialTab=warranty
10/15/2010 10:12:28 PM • LG Flatron... • Answered on Oct 15, 2010
0answers
My LG Flatron 1710S computer
This is a common issue, the power supplies in LCD monitors fail prematurely. (if your monitor has an internal power supply) , Double check all your power connections, but it sounds like the internal supply is toast, (its a simple capacitor replacement to fix, but cost to do this job seems to always outweigh a new monitor purchase) sorry to be the bearer of bad news.If you find my answer helpful albeit poor news, please use the thumbs up feedback.
8/28/2010 7:07:25 PM • LG Flatron... • Answered on Aug 28, 2010
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
8/24/2010 4:29:11 AM • LG Flatron... • Answered on Aug 24, 2010
LG Flatron L1710S 17" LCD Monitor Logo
71 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
wich resolution normal model
  • Computers & Internet
