20 Most Recent
Packard Bell FT500 15" LCD Monitor Questions & Answers
How do I remove the
On the back of the stand/foot there is a rectangular "button"
Press that in and keep it pressed and the foot/stand will slide off easilythe
Carnt remember my password or my email address
If you can't remember either one it will probably be better if you just opened a new account
.IF however you created an alternative account when you opened the account you can't access there are solutions at least with Yahoo and Google.
Signal vertical pin
You need to find an adapter of some kind..Search ebay and other sources for possible cable adapters.
When i switched on my
This can happen if your display resolution settings in windows are set higher then your monitor can support. The display is meant to be set at 1024x768. You can set this by going into the control panel, select display. You will find the option to set the resolution in there,
Regards,
Chris
The picture is not clear
control panel,display,desktop you can select a different desktop from the drop down list also settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
I have a second hand packered bell laptop, how can
for xp go to start, settings, control panel, power options, power meter will display it. start, settings, control panel, power options, advanced, then checking display on task bar and applying will put it on task bar.
My packard bell monitor keeps presenting a blank
Try this for starters. Shut down the computer like you normally do. Next turn it on and while its booting up press the F8 key(keep tapping it). You should get a menu and on that menu, one of the choices is Safe mode. Select it and press enter. This will boot your computer into a Diagnostic mode where you can troubleshoot hardware software and windows problem in general. If you successfully get into safe mode answer yes to the question it asks and then goto your Device manager..you can get there by rightclicking the mycomputer icon and select properties from the drop down menu then select the Hardware tab on top.and click DEVICE MANAGER. In this screen look for your display adapter..higlight your graphics adapter and right click...then select uninstall...now reboot your computer normally this time dont press the f8 key..gointo WIndows normally. This should reinstall your graphics card and possibly fix the problem.
Monitor screen keeps jumping up and down
Download and install the most recent driver for both your graphics card and your monitor from the respective manufacturer's websites.
You will most often find these under "support". You will have to know the exact make/model for both to find the right drivers.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
I need a driver for this kind of monitor
Take a look at this website: The download link is all the way at the bottom.
http://support.packardbell.com/uk/item/index.php?i=spec_ft500&pi=platform_danube_ixtreme
The screen only shows no signal when i switch on
This means it is not receiving a signal from the computer. Check to make sure the cable is tightly connected to your computer and to the monitor. If it is, then the video card on your computer is bad and needs to be replaced.
On / Off switch problem
March 23 2007
This problem is now resolved and the monitor fixed and working.
For reference - it was nothing to do with the ON/OFF switch at all.
The Power Supply / Inverter PCB had two duff capacitors.
These were replaced and BINGO - a working unit.
For other reference - had absolutely NO assistance from any of the users of the various Forums I tried - NO suggestions - NO nothing.
I remember my Grandfather once saying "You get nothing for nothing in this world lad"
Not even advice - He was right.
