Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
This issue can be caused by any of the below possibilities.
Make
sure the monitor is on. If no power light (green or orange light) is
seen on the monitor display try pressing the power button until it comes
on. If no light comes on after several attempts continue to below
connections not connected properly.
Computer is asleep
If
your computer monitor was on and you stepped away from the computer and
upon returning it was black it's likely that the computer is asleep.
Try moving your mouse, clicking the mouse buttons, and/or pressing any
key (space bar) on the keyboard to wake it up.
Connections not connected properly
Make
sure that you are connecting the monitor to the back of the computer in
the 15-pin connector as shown to the right or older computer 9-pin
connection.
If the computer is properly plugged in, make sure it's getting getting power.
If
you are not receiving power from a known working wall outlet and if the
power cord is removable, replace it with the one connected to the
computer and attempt to power on the monitor again. If the monitor still
does not get power or it is not removable, it is recommended that the
monitor be replaced or serviced at a local TV / Computer repair shop.
If the monitor is receiving power, check the status light.
If
the light is orange or flashing ensure that the monitor is not in a
suspend mode by moving the mouse or pressing a key on the keyboard. If
the computer does not get a display by moving the mouse or touching the
keyboard, turn off the computer and monitor and reconnect the data cable
from the back of the computer, and if removable, the back of the
monitor. Turn the computer back on; if you still encounter the same
issue, continue reading through the other possibilities.
Monitor settings are not correct
Ensure
that the brightness and contrast is turned up or attempt to adjust the
brightness and contrast. If adjusting the brightness or contrast has no
affect on the monitor continue reading through the other possibilities.
Does
the computer beep when it is powered on and/or does it appear that the
computer has activity? If the computer does not beep or beeps abnormally
it is possible that the computer itself is experiencing a hardware
issue or is exhibiting a No Post.
Steps on troubleshooting an irregular POST or no beeps can be found on document CH000607.
If
you have followed the above recommendations and are still encountering
the same issue, it is likely that the computer may have either a bad
video card or monitor. The best method of determining this is to do one
or both of the following:
If
your monitor works on another computer it is safe to assume that the
video card or potentially the motherboard within the computer is bad.
Steps in troubleshooting a video card can be found on document CH001028.
If another monitor works on your computer it is safe to assume that your monitor is bad.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague
44 questions posted
511 Questions
111 Questions
110 Questions
63 Questions
53 Questions
