20 Most Recent
Bravetti Quad Blade Food Processor Questions & Answers
Bravetti Food Processor Model KP80B
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us
toll-free at 1-800-798-7398. Hours are Monday through Saturday from
9:00am to 6:00pm Eastern Standard Time.
Model kp80b
You can see all of the blades and their function in the user manual.
The Bravetti KP80B food processor user manual can be read and saved from this website
http://www.euro-pro.com/europro/manuals/KP80B.pdf
If it's not there let me know and I will send it to you.
Rj
I have the Bravetti Food Processor-Model # KP80B.
I went to my manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts.
I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
It will not turn on - just bought this as a new
caveat emptor
there is usually a cooling off period on these types of sales. return it! most estate sales suggest testing before bidding or give statemnt that it has been checked. contact selling agent
Please rate my help++++Thanks for using FIXYA
Food processor
overstock.com/Home-Garden/Food-Processors/.../subcat.html\
Try this site- good luck , ned
Bravetti Model # EP 545
type bravetti i the search bar. one of the results returned may be your source. Good Luck, Ned
Bravetti Quad Blade 6 Cups
unplug it, then use the blade tool to rotate the motor by hand a few times. Not all are tested and turn it by hand will set the brushes. Plug it in and see what happens If you have to turn it several more times make sure to unplug it.. Good Luck, Ned
Not coming on
Does it have a switch that doesn't work? Unplug it and use the blade tool to rotate the whole motor . Turn it several times. Not all are tested and sometimes the brushes aren't seeated. Rotate in direction of normal rotation. Several rimes. Good Luck _Ned_
