20 Most Recent Hotpoint HSM25GFRSA Questions & Answers
I have a HSM 25
Drain line is clogged, clear the drain behind the freezer back wall with hot water and you should be good to go.
1/1/2018 10:41:09 AM • Hotpoint... • Answered on Jan 01, 2018
I have a Hotpoint, model # Hsm25gfre sa, that is
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
8/26/2017 1:07:15 PM • Hotpoint... • Answered on Aug 26, 2017
2answers
My hotpoint refrigerator leaked out all the freon. Can I repair it myself?
this hot point or ge had freon leak at evaporator coils. I replaced that piece and here is video.
10/10/2015 7:46:11 PM • Hotpoint... • Answered on Oct 10, 2015
2answers
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
10/16/2014 12:47:26 AM • Hotpoint... • Answered on Oct 16, 2014
My refrigerator has stop getting cold
Probably the compressor
4/14/2014 3:33:01 AM • Hotpoint... • Answered on Apr 14, 2014
Freezer compartment warms to 60 degrees for about
should always change sensor before the board.
10/15/2013 12:26:20 AM • Hotpoint... • Answered on Oct 15, 2013
2answers
The water stopped flowing from the despenser. So I
gfd
dfg
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
9/18/2013 8:36:12 PM • Hotpoint... • Answered on Sep 18, 2013
Frost build up in freezer
u got a leak
8/9/2012 1:19:42 AM • Hotpoint... • Answered on Aug 09, 2012
How to change hotpoint fan
To which fan are you referring?
3/31/2012 6:25:07 PM • Hotpoint... • Answered on Mar 31, 2012
How to change main board
Your main board is located behind a cover on the right side (looking at it from the rear) just above the open bottom. Take a digital photo of it once you open up the enclosure and mark ALL wires. Before you start to change it out visual check that it has the same characteristics as far as size, terminals, ect. Once you are sure you have everything marked and know where they go on the new board, you will need to first make sure the refrigerator is unplugged, and then using a small amount of force, pull it straight out. It is mounted on four standoffs that use friction to hold it in place. Disconnect the wires one at a time and connect to new board. Press the board back onto the standoffs and power up the unit.
1/7/2012 10:54:59 PM • Hotpoint... • Answered on Jan 07, 2012
Ice maker stopped making ice
The ice maker not making ice.In this case the water passing line and water valve needs to be inspected.--
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
10/10/2011 7:49:02 PM • Hotpoint... • Answered on Oct 10, 2011
My hotpoint side by side is not dispensing water,
In this case the dual water control valve side that turns the water on for water dispenser found here as location 800 in photo=> HSM25GFRASA Motherboard and Compressor Components
I believe you replace this part=> WR57X10051 Water Valve - Dual Outlet
And you will be good to go for dispensing water! Click here for a Service manual that will work with your model=> Here Please rate this solution and If you have any questions please let me know, Thank You Sea Breeze
10/10/2011 9:31:19 AM • Hotpoint... • Answered on Oct 10, 2011
Freezer not getting cold refrigerator
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/21/2011 2:30:40 AM • Hotpoint... • Answered on Sep 21, 2011
My hot point just stopped
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
9/20/2011 5:02:01 AM • Hotpoint... • Answered on Sep 20, 2011
The unit was making a pinging sound then it
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
9/19/2011 2:59:32 AM • Hotpoint... • Answered on Sep 19, 2011
0answers
Hotpoint HSM25GFRSA Logo
92 questions posted
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Refrigerators
Most Popular Question
trouble
  • Refrigerators
