20 Most Recent
Samsung VP-W70U Camcorder Questions & Answers
Samsung VP 500 L Help !
BAD CCD. SAMSUNG IS KNOWN FOR THIS. YOUR OLD TAPES WITH GOOD RECORDINGS PLAYBACK GOOD? YOU CAN RECORD AUDIO BUT NO VIDEO ? IT IS A BAD CCD
Eject...L for no reason
EJECT....L means that your camcorder has a mechanical failure.
after power reset (taking out the battery and putting it back in) and the camcorder is still doing the same thing you should send your camcorder in for repair
Video playback
may still need to be cleaned andy.Sometimes cleaning tapes wont get the dirth out.This is more than likely what is wrong.How old is cleaning tape you tried may be time to try new cleaning tape,.
Focus trouble
If your unit has a switch for manual focus, put it in manual. If you cannot focus the unit in manual you have a problem with the lense and it will need repaired and/or replaced. If you do not have manual focus you will not be able to troubleshoot the unit. It could be a lense problem as stated before or a problem with the Auto Focus system, perhaps just out of adjustment, or something more serious. Either way if you are not capable of camcorder repair you will have to seek the help of a reputable repair shop. Good luck.
Focus trouble
I believe that this is the same question which I answered previously. Here is the answer again - If your unit has a switch for manual focus, put it in manual. If you cannot focus the unit in manual you have a problem with the lense and it will need repaired and/or replaced. If you do not have manual focus you will not be able to troubleshoot the unit. It could be a lense problem as stated before or a problem with the Auto Focus system, perhaps just out of adjustment, or something more serious. Either way if you are not capable of camcorder repair you will have to seek the help of a reputable repair shop. Good luck.
How do I get my Samsung sc d 353 mini DV tape recordings on computer
To transfer the recordings from your Samsung SC D353 Mini DV tape to your computer, you'll need to follow these steps:
1. Connect the camcorder to your computer: Use a FireWire (also called IEEE 1394) cable to connect your Samsung SC D353 Mini DV camcorder to your computer. Most computers have a FireWire port, but if yours doesn't, you can purchase a FireWire adapter card.
2. Turn on the camcorder: Turn on your Samsung camcorder and set it to VCR mode.
3. Open the video capture software: On your computer, open the video capture software that came with your operating system (e.g. Windows Movie Maker, iMovie on Mac) or a third-party video capture software (e.g. Adobe Premiere Pro, Final Cut Pro) that supports Mini DV tape.
4. Start recording: In the video capture software, select the option to capture video from a DV device. Click the Record button in the software and then press Play on the camcorder to begin playing the Mini DV tape. The video should be captured and recorded onto your computer.
5. Save the video: Once the video has been captured, you can edit it if necessary and then save it to your computer in the desired format.
Note: If you do not have the original video capture software, it is recommended that you search and download compatible software before beginning the transfer process. Additionally, make sure your computer has enough storage to store the transferred files.
Samsung SC-D353 foggy lens - what can I do?
If the lens on your Samsung SC-D353 camcorder is foggy, there are a few steps you can try to clear it:
- Clean the lens using a lens cleaning solution and a soft, lint-free cloth. Be sure to gently wipe the lens in a circular motion, taking care not to scratch it.
- If the foggy appearance persists, there may be moisture inside the camcorder. You can try using a hair dryer or a can of compressed air to blow out any moisture that may be trapped inside the camcorder.
- If the foggy appearance is still present after trying these steps, there may be an issue with the lens itself. In this case, you may need to have the camcorder serviced by a professional.
I hope this helps! If you have any further questions or if you are having trouble clearing the foggy lens on your camcorder, don't hesitate to ask.
Samsung VP-D103 flashlight not turning off.
Please remove the memory card and hold the power button down for 15 seconds. If that does not turn the light off, please remove all batteries from your device. Please stay away from the power outlet where the camcorder was initially charging. Thank you.
