20 Most Recent
Orion 19DFLB (Black) 19 in.CRT Conventional Monitor Questions & Answers
My monitor sounds like it is leaking a gas?
Hello
Right click on the dersktop and go to propperties.
Now you need to adjust the frequency of the monitor.
Listen to when you hear the least noise. Hope this can help you.
Best regards
Andrea
Display on and off
you have a blown capacitor on the motherboard use a voltimeter to find and replace it parts are very cheap from maplin at around 70 pence each
Orion model 15dcl
push power
Well, most common failure in the LCD monitor is due to bad caps, worst case will be the lamp assemblies.
So look for bad caps first.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
The monitor will not come
john855, Need to know model and "date of manufacture" from rear of unit to provide you with some help. Is unit LCD or CRT type of display? Is unit powered by a wall outlet or is it connected to a multi outlet "power-strip" ?? 12fixlouie
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
