20 Most Recent
Samsung SC-D103 Mini DV Digital Camcorder Questions & Answers
Display flashing
It is telling you that the scene is too bright for the current settings - use a smaller aperture, or a lower ISO rating
Samsung camera won't record, light won't turn off
I am grateful to Mr. beck ham for his fix involving the date and time. I read his answer and realized that I, too, left my camera on a shelf for a long time and I also didn't have a lithium battery installed.
When reading about his proposed solution, I knew that I didn't have a DV cable. I also knew that my computer doesn't have a DV port and so I would to buy a card, plus a cable. This was going to get expensive.
I called Samsung. They acted like the camera would have to be sent in for repairs of course. 110.00. No thank you.
Then an idea came to me. If the issue had to do with the date and time being lost because of not having the lithium battery, maybe if I put a battery in, it might solve the problem. But didn't seem likely.
Before going to the store to get a battery, I thought what the heck... I'm going to go into the menu settings and set the date and time. Can't hurt.
Guess what? My viewfinder and LCD screen are working now! I didn't have to connect my camcorder to a computer to reset anything. All I had to do was set my date and time!
Memory card error
When you tried to format, did it complete formatting? If format failed then the memory is bad. Buy a replacement. Format should be completed in the camcorder for it work right.If format completed, and you can write to and read from the memory card on the PC, then there may be a problem with the camcorder card reader. Try blowing out the card slot with canned compressed air. (Don't use a tire inflator) And gently wipe off the contacts on the card with a QTip dipped in alcohol. Good luck.
Samsung SCD103 Camcorder
I own the same camera, I have had the same problem on and off for years. Here is what the solution is: ON THE TOP OF THE CAMERA THERE ARE A COUPLE OF BUTTONS WHERE THE PLAYBACK IS AND REWIND ETC... YOU WILL ALSO SEE SEE A BUTTON " BLC / MULTI DISP. wHEN YOUR VIEWER IS BLACK PRESS AND HOLD THAT DOWN AND YOUR PICTURE WILL COME BACK UP. I don't know what this feature is for maybe a lousy fade control, but this will bring your picture back in to the viewfinder. Good Luck...
I have the samsung mini
http://www.digital-camera-battery-charger.co.uk
http://www.battery-charger.us
http://www.power-jack.net/
We are committed to the laptop battery, digital camera batteries, camcorder batteries, PDA batteries and Chargers, development, production and marketing services, the products sell well not only 11 years in Europe, America, Korea, Taiwan, Hong Kong and Southeast Asia and other countries and regions, but also through all major cities across the country to establish a sales agent in the form, the establishment of a comprehensive sales network and after-sale service system, the first class products and perfect after-sales service to consumers.
Can i use a 2gb
Yes, but memory stick only use to save only for still images not for movie purpose.
Thanks.
Lamp lights without command no longer open in the
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
