20 Most Recent
Acer AC713 17" CRT Monitor Questions & Answers
Hcm 582 monitor not display show
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Not power on
Check Power cable connected properly, plugged in to power socket
and make sure monitor & power switch on,
if still not power on Replace power cable.
My acer AC713 monitor's brightness value gets reduced to zero.
Dear sir,
This is common problem arises mainly due to moisture,especially in rainy season,Monitor front panel control buttons remain pressed,due to deposition of ferric oxide and moisture in between monitor botton panel and circuit board.So you can dry this moisture by hanging a bulb of 60 watt nearer a monitor about 4-5 hrs,(too near may damage the internal heat sensitive parts.).It solves your problem.....and also you may clean the inner monitor button contacting circuit by means of PCB cleaner to wipe out ferric oxide deposition.
if you had any query regarding this issue leave a feedback we glad to assist you.
good luck.
Power on problem
If when power is applied it fails to make any sign of activity upon pressing the power button, then the power supply has likely failed. In this case, it is far cheaper to just replace the monitor.
Resistor
LG 500G MONITOR
The problems is this set powersupply indicator led is blinking
Out of range
acer ac 713 crt monitor picture incorrect (left&right)
