20 Most Recent
Samsung 710V 17" LCD Monitor Questions & Answers
Samsung 710v no display, video
do one thing remove your monitor from cpu and turn it on only your monitor if check signal cable display is comming on your monitor means you have your cpu problume
thanks
My monitor is on but
The ideal way is to crros check to see if the PC or the monitor is the suspected fault. So connect an external monitor to your PC and if this works OK then the PC is cleared. Now check the monitor to confirm. If not there are errors in the signal processing section- the point where the input signal from the PC has to be processed. Possible failure of the input IC.
If however the PC does not output it is failure of the graphics card and must be substituted to confirm and replace.
Samsung 710v ima problem zamjenjeni kondenzatori i
Kondenzatori moraju imat mali parazitni induktivitet inace nevaljaju , provjeri mali kondenzator u ispravljaču ( on daje snagu ispravljaču ) provjeri diodu i kondenzator u zaštiti u primaru ispravljača ,
Hi
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
- Set your Screen resolution to 1280X1024
Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Samsung 710v test good
For anyone having this problem i suggest to get a manual from asnerejas. His notes helped me out totally.
Its not something you would spot looking at its inside...
It saysmy pc video resolution is out of range
to chabge resolution go to click start
control panel
apperance and themes
display
settings
and down towards lower left hand you'll see screen resolution
then move bar to 1024*768
Mark
