20 Most Recent
Samsung 997DF 19" CRT Monitor Questions & Answers
My laptop got automicaly turn up after 1hrs 30
hey possible reason is your memory, try to increase your memory, or your pc have lots of worms on it, so make sure you clean up your pc, and also on the software that you installed, try to uninstall things you dont need.
Possible soyware
try the following online spyware scanner. it will not need to download anything cause it does the scan online. its safe and convenient.
Link
Spyware infestation
This website should help you out. It's really good, try it. It's free.
http://www.microsoft.com/athome/security/spyware/software/default.mspx
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Screen patch
Sometimes lcds will turn a yellow/brown/redish colour if they overheat. normally this will not cause long term damage to the screen but it is not good for it, try letting the monitor cool then using commpressed air to get rid of dust or attach a small fan to see if it helps. This may not fix the problem but should confirm if thats what it is.
Monitor will not power up
This sounds like the common STR type regulator IC problem that goes bad with most of these samsung monitors. Not a hard thing to fix,but withg the hi voltage and the safty issues involved, It would be best to have a pro fix this for you. Good Luck
How do I find the instruction manual with codes for my Samsung 32" curved screen monitor ?
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
4/13/2024 10:32:28 AM •
Samsung...
Answered
on Apr 13, 2024
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
