20 Most Recent
Canon MV800i Mini DV Digital Camcorder Questions & Answers
Will not record or play
You might need to replace the whole tape deck or the recording heads as they do intend to wear out after a while.
How to download to a computer
Maybe the simple way to do it remove your memory card and buy an usb adapter and you can open it in the computer easily.
Tape not loading
I READ THE SOLUTION TO THIS PROBLKEM THIS MORNING ONTHIS WEBSITE, BUT I CAN NO LONGER FIND IT.
THE SOLUTION SUGGESTED DROPPING THE CAMERA ON TO A CARPETED FLOOR FROM HALF A METRE HIGH AS A FIX.
THERE WAS ALSO A POSTING FROM A GUY WHO HAD FOLLOWED THIS ADVICE AND IT FIXED HIS CAMERA.
SO I DECIDED TO FOLLOW SUIT AND I DROPPED THE CAMERA ON TO A CARPETTED FLOORT FROM HALF A METRE HIGH AND WHEN I TRIED IT WITH THE TAPE IT WORKED, NO JOKE, THIS IS AN HONEST AND TRUTHFUL REPORT.
REGARDS
EDDIEWEST
Hello. I have a problem.
Search for "WinDV" on Google and download it. It is a very small and free program but it does the job very well. You must have a DV connection on your PC/Laptop and you will need a firewire cable to connect to the camera.
When ever i start the
Have you checked the "button" battery (CR1616) under the big battery? Probably needs replacing.
I am looking for the
Here is a link where you can download the MV800i Drivers.
http://www.nodevice.com/driver/MV800/get37143.html
Canon camrecorder will not load cassettes take
Believe it or not, but I found a possible solution for that in another forum. The suggestion was, to let the camera drop from about 0,5 m height onto the floor. Make sure, that there is a carpet underneath, which prevents the camera from severe damage.
This is no joke - I have let it drop once and the cassette was loaded and everything worked fine. There might have been a sensor problem or a little hickup in the mechanic.
Try it on your own risk - but what do you have to loose ? I wanted to sell the camera as broken on ebay, but now, I have a running camera again.
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
I need the driver for
Hello. By accessing
THIS link you will be able to download all the drivers you need for your CANON MV800i.
Choose your operating system, click on download (bottom), enter the code shown and then download the file to your computer (desktop for example). Run it and install it properly!I hope it works!
Thank you for using FixYa!If you have any other questions, please leave a reply!
I bought a DV/Firewire cable,
Connect the camera to the Mac with the firewire cable.
Open iMovie and capture the required footage.
Send the iMovie project to iDVD and burn a disc.
When I play back the screen has grey horizontal
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
