20 Most Recent
Sony VAIO FRV Notebook Questions & Answers
How to download sony vaio
Mr Felnuz, PCG-7G2l is the serial # and not the model #.
Model Numbers are usually located on a sticker located on the
back or bottom of the unit. They may also be listed on the product
manual.
You can also find the model # by clicking on start, select run, then type"msinfo32" in run.
Press enter, there you can see the system model.
Model # starts with initials VGN.
Once locating the model #.
Visit this website to download drivers.
www.esupport.sony.com
Sony Vaio PCG 7v2l won't turn on
this may or may not be the solution but its some sort of indication of what is going on. Ok when you plug the ac adapter do u get a flashing light to indicate your batter is being charged? If you do then there is power going through the laptop to the battery, which is great. Now if you don't have the indicator flashing then it could be that the where the AC adapter plugs to the laptop could be now faulty. The other one could be that the AC adapter plug i.e. head that goes into the laptop some how internally has a severed connection.
comment on what you find and ill see what else i can advice :)
Plz rate me
My vaio PCG-9J2L doesn't turn
You may have a short. However, when troubleshooting, you should always rule out the obvious first. In this case the is another culprit to possibly blame for those symptoms that is easier to check. The capacitors. When a capacitor goes bad they are incapable of holding their charge and dropping voltage to zero under a load. To check them, do a visual inspaction of them. Look for bulges in their casing as well as corrosion/electrolytic fluid leaking from them. If you find one... power the device on (while its diconnected from the main board) and check the cap's voltage. Then power the device off and check the voltage again. There should be some life to it after the power is off. It there isn't, a bad cap is to blame.
Have sony vaio pcg-7v2l but
You are getting the model from the unit's bottom which is incorrect
Search
around the lid or open <system information> window from the start
menu - accessories - system tools OR Run - type msinfo32 and press
enter
On the right side of system information you will find system model
Then
go to esupport.sony.com and enter the model vgn... or vpc... or vgc...
something you found before. If it doesnt find it there its because the
model is foreign and you need to go to the sony support page from the
country of purchase
Sony vaio vgc-c190x stop
try taking out the batt, leave the mains plugged in, if it starts up then you need a new batt
hope that helps
My battery on my sony vaio model pcg7v2l will not charge
Just a quick idea, try going & setting your BIOS to optimised defaults.
Oh, just one Question & what do you mean by freezing it?
please don't tell me it's what i think it means,you've never gone & done something stupid like put it in a freezer have you. NO,just ignore me mate coz surely common scene would have stopped you.
BUT:
if you have then that's probably it deferentially fucked.
Spilled water on keyboard weeks ago nothing is
Its going to be a write off....contact your insurance company for claim.
I have processed a few like yours and the damage is terminal. By the time you price up parts / labour its cheaper to replace.
Bought used Sony Notebook PCG-FRV26
Can you make sure that the Music CD is not write protected. This will disable you to write the contents of the CD into an other Disc.
Kindly comment
