20 Most Recent
Magic Chef CPL1110AD Gas Kitchen Range Questions & Answers
Self lighting burners won't light without matches
You will need to remove one of the burners you will see three small pin holes you can use a small safety pin or small paper clip and clean these hole free of carbon build up, also around the burner is the port that the flames comes from, make sure all the port is free of any carbon build up, replace the burner and then give it a try.
How do I turn off the pilot light in my Magic Chef 31000paw oven? I think when it stays on it is wasting gas.
I don't know. While half a century ago it was common that pilot lights would be permanently lit to provide instant lighting of oven and hobs, because they did consume a significant amount of gas they fell out of favour and spark ignition became reliable.
Amid a number of related and unrelated accidents the gas oven began to be seen as potentially dangerous and so they were fitted with a couple of safety devices so for a considerable time the pilot light has to be relit every time the oven is used and the pilot light will be switched off when the oven burners are turned off.
Thinking back a long time, the pilots of our old cooker could be turned off using a screwdriver to turn a central service valve hidden under the hob spill tray.
Electric spark will not work, burners will not light
The spark electrode sends a spark to ignite the gas in the burner assembly. If the spark electrode is defective or worn out, it might not produce a spark, or the spark might be too weak to ignite the gas. As a result, the spark electrode will make a clicking sound when the burner is turned on, but the burner won't light. If the spark electrode is defective, replace it. I’m happy to assist further over the phone at
https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
