20 Most Recent Sony ( CRX230AD/U ) CD-RW Burner Questions & Answers
imnot sure what you are reffering to by (i can not found) ? if you cant seeit in windows explorrer itmight be a registry problem
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
http://www.ebay.com.au/itm/SONY-CRX820E-CRX810E-DVD-CDRW-Laptop-Slim-Drive-/370285218816?pt=PCC_Drives_Storage_Internal&hash=item5636b80c00
Ebay $28.50+ $30.45 postage america this might not be the right one but it might guide you to one
postage is the killer you might be able to find one closer to your place of residence for free local pick up
hope this helps you
Sony (... | Answered on Oct 14, 2011
hi,
1.this should be drive or lens problem
2. contact sony service centre
3. use disk cleaner
4. change the driver
thanking u
Sony (... | Answered on Apr 12, 2011
Sir go this LInk! http://sony.storagesupport.com/cdrw/crx230addwn.htm
Sony (... | Answered on Sep 06, 2008
I'm pretty sure the cables for all writers/readers are the same. One thing is for sure, if they fit they will work.
Sony (... | Answered on Dec 24, 2007
the capacitors in side on the amp have gone weak. it has noticed the fault and is telling you. check the capacitors look for any sight of problems look for the end being popped up and brow-black gunk on the board around them tackie to the touch and change them. also give the boards a good clean out using a new paint brush sweep the dust out.
Sony CRX... | Answered on Oct 20, 2013
The push-button activates a small motor that turns a small rubber belt/ band that opens the cassette door. Since it's not been used for 10 yrs, I would say these belts would have deteriorated and broken. you will need to replace them. the best bet is to open it up and check. if its the case, you should be able to source the belts on ebay.
Sony Computers &... | Answered on Dec 03, 2019
this is easy, that OUT OF range means
the PC sending video is sending and illegall higher resolution
than the projector supports (or even less, on this old junk)
the manual on that old projector is clear on that. max.
SONY VPL-EX4 2007, 13 years old now.
and back then projectors STINK !
your manual shows this, and stinks.
what stinks worse is no matrix of legal H./V resolutions shown in the manual. (shows only 1)
so set the PC to 1400 x 1050 and do not use others . ok.
and 60Hz, are you in USA? not stated country.
Sony Computers &... | Answered on Nov 28, 2019
no OS stated, W10?
the drivers for your camera/mic are wrong, reload them from SONY..com
Looks like you are having a bad LCD screen, This could be due to drop damage. Cracks can be so tiny and may not be visible immediately. I would take it to a technician and get a screen replacement.
Sony Computers &... | Answered on Nov 27, 2019
You probably need more ram memory. Also try playing a video in your dvd player. If it plays slow and choppy you definitely need more ram memory.
If you are trying to play a video from a website (streaming) then three things can affect how smooth it plays.
1) Memory - your ram memory might be low
2) The website might be experience heavy traffic from many users.
3) The Line Speed of your internet connection from your service provider might be slow. For example: AT&T sells about 3 or 4 different packages and each one increases the line speed for uploading or downloading. If you buy the low end package the line speed is very slow on uploading and downloading or streaming. It's ok for just surfing, but nothing else.
Sony Computers &... | Answered on Nov 08, 2019
1st leave the battery out,
then power only with AC power pack
push power for 10seconds and releases.
the batteries are bad, as more are, in the wild. most.
Sony Computers &... | Answered on Sep 12, 2019
all things can be repair,
only price to do so matters.
one mans garbage is others treasure.
can't speak for you ever.
but in my hands yes, garbage.
spend hard cash on newer more supported products.
2010 or newer is good rule.
Sony Computers &... | Answered on Aug 31, 2019
Might be motor-boating. Used to be a fairly common fault with older less sophisticated circuitry. The cause could be anything from a fault in an interim power supply to stray feedback causing an oscillation with a low speed harmonic. Considering your description it could be the latter - impedance mismatch maybe, between the external mic and the amp input...
Sony Computers &... | Answered on Aug 20, 2019
Sounds like you accidentally pressed the power button while you were dusting and turned it off. You just need to turn the HT-S200F back on.
It's the 1st button on the left of the control panel, which is located on top of the soundbar, in it's center. .
https://www.sony.com/electronics/support/res/manuals/4727/47274141M.pdf
Sony Computers &... | Answered on Aug 19, 2019
Have a look at VLC media player at http://www.videolan.org/vlc/ It's free and plays pretty much any video format, including DVDs
Sony Computers &... | Answered on Aug 16, 2019
If you live in the rural area and you have a broadband connection/modem connected to the Netgear wireless router, then I suggest you look at my instruction on how to configure the wireless router with encryption (security) - click on this link for instructions. :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sony ( CRX230AD/U ) CD-RW Burner Logo
Popular Tags
5 questions posted
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
CRX Sony
  • CRX Sony
Most Popular Question
cd burner replace sony crx310s db
  • Computers & Internet
