20 Most Recent
Magic Chef MCM660A Microwave Oven Questions & Answers
How do I replace the fuse ?
The problem may not be a fuse. Have you checked the door switch? Over time it will get dirty and prevent the microwave from turning on. You can use an electronic cleaner under pressure to clean it.
The Display on my microwave says "LOCKED"
The control lock shuts down the control panel pads to avoid unintended use of the microwave oven. To unlock/lock control, the microwave must be in standby mode, touch and hold stop/clear for 3 seconds until one long tone sounds and the display clears to show an outline if the display area. Repeat to unlock control, and return display to the time of day, if any pad is touched while the control is locked, there will be no response from the microwave oven. hope this helps.
I want to know how
that unit is 700 watts. hope this helps and please dont forget to rate me Thanks ken
WATTS
The output power is 1000W and that's near the high end for a consumer microwave. Hope this helps.
Please write back with more details if you need further help.
We do appreciate your very thoughtful rating of our answer.
No power in microwave - vm11b8p magic chef
The incoming power wire goes onto a small pc board, the fuse is located onto that small pc board. If it is not visible then you have to remove it and turn the board around. You should locate it on the other side
