20 Most Recent Magic Chef MCD990W Microwave Oven Questions & Answers
Microwave wont turn on
unplug take cases off. look for fuse. if fuse is blown. go get new one should work.
3/3/2016 7:17:08 PM • Magic Chef... • Answered on Mar 03, 2016
0answers
Oven works fine but plate doesn't go around anymore.Little driver in center doesn't turn anymore.
there is a belt on bottom its broke
4/1/2013 4:02:30 AM • Magic Chef... • Answered on Apr 01, 2013
0answers
2answers
TURNTABLE AND LIGHT NOT WORKING
It will cook entirely different ... you will want to turn the food occasionally to assure complete cooking.
You probably have a burned out lamp ... look inside for an access panel. If none, you will have to remove the cover. There are probably 8 to 10 screws and they may be Torx - Torx is a star shape, available at auto parts store of Sears (K-mart).
Once inside - DO NOT TOUCH THE SILVER CAN - LETHAL.
Find the lamp, check it out. If burned, get a replacement at your hardware or appliance store or maybe at a Big Box store.
I hope this helps you.
a
10/1/2012 5:04:08 PM • Magic Chef... • Answered on Oct 01, 2012
Magic chef 990W microwave clock keeps resetting.
Make sure that the program controller is receiving power - step down supply. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Since the clock is resetting it is a fault on the main board and the processor as it is tripping. So check power, check for faults mentioned above on the board. Also if there is fault of the magnettron leak or a waveguide leak then clean and check insulation.Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had depositedthen it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test. If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
9/23/2011 12:20:06 PM • Magic Chef... • Answered on Sep 23, 2011
Keypad not working ... not allowing any input ...
came on by itself
7/14/2011 8:46:01 PM • Magic Chef... • Answered on Jul 14, 2011
Microwave door does not close; the latch does not
The microwave oven door latch is a safety part preventing energy leakage. For safety reasons, i will advice you get a technician to help because you will need to replace the door lock and to replace the door lock you will have to take apart the door, and that is no easy task. Best is to get a technician to help replace the door lock.
7/8/2011 10:12:39 PM • Magic Chef... • Answered on Jul 08, 2011
Hi how r u?? my microwave just stoped
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
6/10/2011 2:54:42 AM • Magic Chef... • Answered on Jun 10, 2011
No power
there is a fuse. check it. loacation will be specified in the manual.
4/14/2011 9:15:03 PM • Magic Chef... • Answered on Apr 14, 2011
The microwave won't turn on.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
3/5/2011 1:55:32 AM • Magic Chef... • Answered on Mar 05, 2011
How do you change a magnatron
It is illegal for a homeowner to perform this task -- must be done by a licensed repair facility. There is too much potential for creating a significant radiation hazard to which you would not want to expose you, your family, your pets and/or your guests.
I know this is not the answer you wanted, but it's the only "right" solution.
Charlie
2/8/2011 12:20:28 AM • Magic Chef... • Answered on Feb 08, 2011
Not heating
Basic
heatman101
1/28/2011 11:12:27 PM • Magic Chef... • Answered on Jan 28, 2011
It not heating the food
Most likely the magnatron has gone bad. Here is a place I found that carries these parts.
www.repairclinic.com
1/26/2011 4:31:58 PM • Magic Chef... • Answered on Jan 26, 2011
Brand new and door
door switch is bad...Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
12/27/2010 1:20:25 AM • Magic Chef... • Answered on Dec 27, 2010
Magic Chef microwave oven will not work. No
heatman101
11/12/2010 4:16:47 AM • Magic Chef... • Answered on Nov 12, 2010
I inadvertantly ran 220 to my RV. the main breaker
probably lost; the main board is likely fried.
8/30/2010 7:49:05 PM • Magic Chef... • Answered on Aug 30, 2010
Magic Chef MCD990W Microwave Oven Logo
48 questions posted
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Microwave Ovens
Most Popular Question
turntable light not working
  • Microwave Ovens
