20 Most Recent HP Jornada 540 Pocket PC Questions & Answers
How to install windows xp step by step by boot setp in hp 540
hp.comor google it?nobody on earth uses XP nor palm pads now.it is now forgotten. and XP is virus magnet.that battery is no good too. now.
6/9/2022 1:13:48 PM • HP Jornada 540... • Answered on Jun 09, 2022
2answers
Having a hard time installing
If you do a new, clean install of XP in 2018, one would be missing hundreds of updates from Microsoft that would be very hard if not impossible to get. Some of those updates might apply to software that you want to use in conjunction with Windows XP. And if it is an older PC, you might not be able to find driver support for the particular make/model, and XP might not have the drivers you need. How many times have you heard someone say, "I just reinstalled XP, but now I am missing drivers?" This could be part of your trouble, because even if your XP updated all the way up to April 2014, you could still be missing HP updates provided by HP/Microsoft through Windows Update. Since Microsoft has not supported XP since April 2014, I would recommend not using it anymore in 2018.
1/29/2018 7:11:21 PM • HP Jornada 540... • Answered on Jan 29, 2018
HI! I
why not ask HP, they had books on it but is obsolete this device. its old. and zero support. (what good is it ?) over CELL smart phone. ? here is real HP ask here, maybe some wild guy has manual squirreled away. https://h30434.www3.hp.com/ ask both questions.
8/26/2017 2:15:07 PM • HP Jornada 540... • Answered on Aug 26, 2017
0answers
Drivers
Be the first to answer 5/3/2013 3:02:25 AM • HP Jornada 540... • Posted on May 03, 2013Be the first to answer
2answers
I want to install windows xp pro SP2, on my hp540
check the bios settings and set the multiboot settings.........
7/14/2011 1:32:37 PM • HP Jornada 540... • Answered on Jul 14, 2011
I need to install win
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
5/11/2011 5:33:39 AM • HP Jornada 540... • Answered on May 11, 2011
Msfeedssync.exe has generated errors and clossing
c bizzar cher pas!
3/17/2010 11:06:50 AM • HP Jornada 540... • Answered on Mar 17, 2010
To install xp2 on my hp laptop 540model
Just do this
8. This should do.
9/20/2009 3:21:20 PM • HP Jornada 540... • Answered on Sep 20, 2009
Pocket Access - does it exist on HP540?
No, sorry, the Jornada 540 does not have Pocket Access on it. The Jornada 720 does, however...
9/12/2005 6:54:41 PM • HP Jornada 540... • Answered on Sep 12, 2005
Screen problems with 540
Sounds like the shock from being dropped may have caused some internal connections to the screen to become loose causing the stripes or blank screen. It is also possible something might have been damaged. It sounds more like a loose connection and not any damage, but I don't know for sure. My suggestion would be to get it looked at by a professional.
9/12/2005 6:08:13 PM • HP Jornada 540... • Answered on Sep 12, 2005
Software Upgrade
As best as I reemember there is no way to do it as the OS and apps are burned into ROM. The 568 was the only Jornada that could be software updated.
9/12/2005 5:10:36 PM • HP Jornada 540... • Answered on Sep 12, 2005
Contact sort
Sorry, no can do. The only thing you can do is sync it with Outlook and use the sort options there.
9/12/2005 5:09:36 PM • HP Jornada 540... • Answered on Sep 12, 2005
Change language in hp jornada 540 pocket pc
Sorry, the OS on the Jornada 540 is in ROM and cannot be changed.
9/12/2005 4:55:45 PM • HP Jornada 540... • Answered on Sep 12, 2005
Battery problem
First I'd try a hard reset (tiny red button at the back), if that doesn't help, it is likely to be the battery.
9/12/2005 4:44:48 PM • HP Jornada 540... • Answered on Sep 12, 2005
Contact Transfer for Journada 540?
The Jornada 540 should have come with Outlook 2000. It works fine in Windows XP. When you Sync your computer and Jornada 560, the contact information should transfer from one to the other until both have the same contact information. Under the Tools pulldown on Activesync, select Options. Sync Options allows you to sync your Contacts by checking the box next to it. The next time you sync, all of your contacts from your 560 will be in your Outlook. When you get your battery replaced, just sync again and all of the contacts in your Outlook should transfer back to your 560. The other option is to get a Compact Flash memory card and backup your info onto that. Its much easier. Simply restore your info from your memory card when the battery is replaced. Hope that helped you.
9/12/2005 3:55:19 PM • HP Jornada 540... • Answered on Sep 12, 2005
O/s upgrade?
Sorry, the Jornada 540 has the OS in ROM and is not upgradable. Additionally, the 540 uses the SH3 processor which Microsoft does not support in the more recent versions of the OS.
9/12/2005 3:51:49 PM • HP Jornada 540... • Answered on Sep 12, 2005
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
HP Jornada 540 Pocket PC Logo
Popular Tags
27 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Jornada HP
  • Jornada HP
Most Popular Question
need install win
  • Computers & Internet
