20 Most Recent
Sony Play Station 3 System Backpack For Ps3 Questions & Answers
Play station controller....is the 4 red light suppose to keep flashing
It's flashing for one of two reasons. It is either about to die because the batteries need to be charged. Or it is hooked up and charging. Those are the only two reasons I can think of for them to flash. Possibly not connecting, but you would have probably said that if it was the case.
5/13/2016 9:14:28 PM •
Sony Play...
Answered
on May 13, 2016
It won't send video and audio
1 To reset your PS3 back to its original settings go to options. Select system settings and click reset system. WARNINGFollowing these directions will wipe ALL data from your PS3 system. Do NOT do this,
(this will reformat the HDD)
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
3 After you complete the operation and restart the system, the initial setup screen will be displayed. Follow the on-screen instructions to perform initial setup of the system software. Note that performing hard reset on your PS3 will return your password to 0000. However, note that all settings other than the password will also be reset. Once these settings are reset, they cannot be recovered.
11/25/2013 11:37:36 AM •
Sony Play...
Answered
on Nov 25, 2013
Netflex com support
That is a sometimes common problem on the Netflix server's end. The best work around only works about half of the time and that would be to exit the movie or show and find a series with multiple episodes and start an episode for a minute or two, then go back to the show you were wanting originaly.
This causes the session cach on the server end to remove the old data for the new show, so the one you wanted originally will be forced to attempt reloading.
10/15/2013 12:46:21 PM •
Sony Play...
Answered
on Oct 15, 2013
Sony Playstation 1 replacing the power unit
Before you start make sure that the console is turned off and unplugged before you begin the process. This is for the 1001 model types. With the 5501 and the 7001 and for the 9001 the process might be slightly different.
Step one: Open up the PS 1 console with a Phillips head screw driver and turn the console upside down and remove the 5 15.8 mm-long Phillips #1 screws.
Step two: While holding the top and bottom halves of the console together turn the PS 1 console back over. Lift the top cover straight up to remove it.
Step three: Unplug the power supply and then gently pull out the power supply cable straight up and out of its socket on the power supply to disconnect it.
Step four: Now remove the power supply and then remove the 2 14 mm-long Phillips #1 screws securing the power supply to the bottom of the case.
Step five: Lift out the outer edge of the power supply slightly, and then rotate the whole entire power supply away from the small clip on its inner edge to remove the power supply.
To reassemble your PS 1 console back together follow the above steps in reverse order.
Compare your new replacement part to the original part You might have to transfer the remaining components or remove adhesive backings from the new part before installing.
Psp
Yes, you need a software to convert a video file to a video format that a PSP supports which is MPEG4/M4V you can check this link for a sample of PSP video converter
http://www.pspvideo9.com/
Hope that helps...........
Can a Sony PlayStation 1 disc be faulty then and not work at all ?
Yes it is possible for a PS 1 disc to be faulty and not work at all. I had that problem with one of my PS 1 disc's was not working so I had bought a second disc of the same game for my PS 1 console and it was working. Try buying a new game disc to see if it works or not if it works then then it was just a faulty disc if it doesn't work at all then your PS 1 console is having a problem with the laser and the lens and the disc drive that needs to be replaced. If it is working on a different system then it could be your PS 1 console. Try a new disc and see if it works first.
Sony playstion 2 Fat scph 30003 - no picture, no sound
There's an option says something like "Audio out" and you can set to Optical or Component (I don't remember quite right), you could try that.
If that doesn't work and the video comes fine out of the composite cable and the audio out of the optical.
Check the cables...
I have a sony blu ray player that I cant get to work with net flix
You need to go online via PC or laptop or tablet to register your device.it must be using the same router.once your device is connected at the sane time as your registered device you can enter the code into the blueray or screen on device.this will allow the blueray to run via internet.I think I am right in saying earlier sony bluerays from Europe/Uk do not run netflix only amazon. The American ones do.
Ps2 multitap
It's the multitap, yours is designed for PS1 games, and PS2 and PS1 games require different multitaps. You have to buy one specifically for PS2.
