20 Most Recent
Miele 24 in. G643Vi Plus Built-In Dishwasher Questions & Answers
My machine says it
You should be able to insert the salt into a container at the bottom of the machine. There should be a screw-top on it. Refer to the user manual on whether you need salt, and how to insert it. The manual/ documentation may have come with a single- use hardness indicator. Alternatively, you can purchase hardness indicator strips. If your electric kettle/ shower has large amounts of white calcium 'fur' in it, they this is a sure indication of hard water, and you should consider using salt
The hose that goes from
Hi Connie - pending on where you are or you can always contact the retailer that sold you the oven? - If I knew where you live I could suggest a few agents or the Miele spares.
Why do my glasses go cloudy
All glasses eventually go cloudy in dishwashers, the problem is far quicker and more noticeable with lead crystal which specifically should never be washed in this way.
The cloudiness cannot be reversed: it's caused by millions of tiny cracks in the glass surface as a result of both the chemical and physical processes inside a dishwasher. Some products claim to include a "glass protect" function, but it just slows down the damage instead of stopping it. Commercial glass-washers used in bars and restaurants also cause this damage, but as the wash cycles are far quicker and the cleaning agent is specifically for glass the damage occurs more slowly. In any case, glasses don't usually last long enough in commercial use to show this damage as they usually scratch, chip, or break before it shows.
All you can do to totally avoid the damage is to wash glasses manually and to never put lead crystal in the dishwasher. If that's not an option, then you can slow the damage by washing glasses at the lowest possible temperature: you'll find that some cleaning products are better than others at low temperature and it's not always the expensive brands.
Sorry there's no fix for your cloudy glasses, but I hope that I've helped to to avoid further damage. Please take a moment to rate my reply.
