20 Most Recent
John Deere 300 / 316 Hydrostatic Tractors Part Manual Questions & Answers
Oil foams in hydro pump and no power steering and no hydrualics work
What happens when they add air to the milk in your latte at Starbucks? It foams. When you aerate the water coming out of your faucet? Lots of bubbles. When you as a kid would blow through a straw into your milkshake and make even more bubbles? Air. Your hydraulic system which is almost always without a doubt under very high pressure, has developed a leak and is sucking air into the system. Get it pressure tested and repaired before you damage your hydro system running air inside instead of hydraulic fluid for lubrication.
Clutch will not engage
Do you have the hydrostatic disengaged,there should be a lever on the RH side of the tractor under the seat pan,(below where your knee would be)when engaged the hydro works,when disengaged,it lets the tractor roll in neutral per-se.
Ecu module
pull plug touch block see if plug is sparking if not check safty switch to be bad jump each one until you see park at plug some swithches just unhook do not jump
How to diagnose a starter problem
Hi rojoby
Remove the starter, hook up the (+) Hot wire to the post of the starter, then take the ground wire(-) from the battery and ground it to the outside case of the starter...if it runs, then the starter is good...if not, replace the starter as it is faulty.
If if runs, then check/replace the starter solinoid, it could be faulty
Please take time to rate me
Bud
