20 Most Recent HP Pavilion ZV5000 ZX5000 Compaq R3000t R3200 series 15.4-inch TFT WXGA LCD Display-350217-001 (350217001) CD-ROM Drive Questions & Answers
HELP PLEASE WHEN I TURN MY LAP TOP ON I GET A
Media test failure Check Cable or error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
3/30/2011 9:09:10 AM • HP Pavilion... • Answered on Mar 30, 2011
0answers
My hp laptop zv pavillion 5000 turn off whe
could be a heat problem. remove the back cover and check to insure the prcessor id getting proper ventilation. the heat sink may be covered with dust.
11/29/2010 7:39:56 AM • HP Pavilion... • Answered on Nov 29, 2010
Display is working but no brightness. The display
did you change the little inverter board? check your brightness by pushing Fn key and left, or right arrow buttons.
8/12/2010 10:58:26 PM • HP Pavilion... • Answered on Aug 12, 2010
Replacing the ODD in an HP zx5000 Pavilion
hey buddy....
if u wanna step by guide for u ODD hardware assembly.....
check out the following link.... kindly scroll down a little.... u ll see something called as hardware guide..... kindly download that manual.....
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=321957&prodSeriesId=369807
its a legitimate hp link for u zx5000.... so u dont have to worry or doubt about the procedures....
i would also recommend u to download all the other manuals pertaining to ur zx5000 from there ..just incase...
it wud be mighty helpful for ya...
hope i was help
thank you
have a nice day
4/10/2009 3:49:29 AM • HP Pavilion... • Answered on Apr 10, 2009
Hp zv 5000 won't charge battery or turn on
you need to remove and install the battery. Some times this works first try others may take a few trys. Mine does the same thing. Good luck
1/13/2009 10:05:26 PM • HP Pavilion... • Answered on Jan 13, 2009
Cant start windows after RAM upgrade
Download or get a memory test utility that boots from some device (a floppy, flash drive or CD-ROM) that your PC can read. Run that test to confirm the installed memory is good/compatible. Loose memory modules and PC boards can be zapped just by touching the connector pins while you handle them. During removal or installation you have to frequently touch the machine's frame or wear an ESD strap before handling the module, to prevent this.
10/22/2008 6:47:19 AM • HP Pavilion... • Answered on Oct 22, 2008
I'm upgrading Ram Compaq R3200 laptop
Found my solution. Was under keyboard. Required opening laptop as far as possible, removing 3 screws from the back that hold the piece of plastic just above the keyboard. With flathead screwdriver lift the right corner of the plastic piece then, with the same screwdriver lift the top center of the plastic piece to remove the piece entirely. Unscrew the 4 screws that hold the keyboard (across the top) and lay they keyboard forward (toward you). THERE is the Ram.
5/23/2008 10:11:17 AM • HP Pavilion... • Answered on May 23, 2008
PAvilion ZV5000 Screen Issues.
does rebooting fix the issue? if so it could be a driver issue.
However I believe its probably a loose ribbon cable. It happens from time to time, the cable eventually loosens up. If your mechanically inclined you can open up the laptop and secure the cable. However if you have never opened up a laptop, theres a good chance you will break a piece of plastic as they are fragile and force must be used in the correct places.
3/16/2008 4:41:39 AM • HP Pavilion... • Answered on Mar 16, 2008
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
Computers & Internet Logo
11 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
display working but no brightness
  • Computers & Internet
