20 Most Recent Poulan WEEDEATER FEATHER LITE 1500 GAS BLOWER- Reconditioned Questions & Answers
How to spool the cutting wire
please see instructions on replacing the line on page 14 of the manual. Make sure you buy the correct line size. Incorrect line size will cause lot of grief and frequent replacement. http://www.poulanpro.com/ddoc/PPOO/PPOO2009_USen/PPOO2009_USen_PP025-545177327_952711878.pdf
9/2/2014 1:00:50 AM • Poulan WEEDEATER... • Answered on Sep 02, 2014
Won stay running
Needs a carb adjustment, cleaning, or possible rebuilt. Try adding a little seafoam and running at half choke for about 5 mins or longer this may clean it up nicely. also check the spark plug.
11/10/2013 1:50:59 AM • Poulan WEEDEATER... • Answered on Nov 10, 2013
Poulan PP4620AVX Gas Chainsaw. What part do I need to convert to tool chain tightening from tool less?
Question edited for clarity and toss in a load of CAPS and punctuation. https://www.google.com/search?q=poulan+pp4620avx+auto+chain+tensioner
Poulan Pro Tool-less Chain Tightening System - ArboristSite
arboristsite.com https://www.arboristsite.com > ... > Chainsaw Aug 4, 2008 - Poulan Pro PP4620AVX the wheel/gear that you turn to adjust the chain (Tool-less Chain Tightening System) is stripped is there a metal gear ... Fix Poulan Pro For Friend - Chainsaw Feb 19, 2014 Poulan Pro chain tightening problem Nov 11, 2016 More results from www.arboristsite.com
2/22/2024 6:31:27 AM • Poulan Garden • Answered on Feb 22, 2024
How do I remove the gas tank on a Poulan Pro PPBP30/30cc gas backpack blower?
I would look on u tube .
11/19/2023 11:55:18 PM • Poulan Garden • Answered on Nov 19, 2023
To remove the gas tank on a Poulan Pro PPBP30/30cc gas backpack blower, follow these general steps:
1. Ensure the blower is turned off and cool before starting any maintenance.
2. Locate the gas tank on the blower. It is typically positioned near the engine.
3. Look for any screws or bolts securing the gas tank to the blower. Use the appropriate tools, such as a screwdriver or wrench, to remove them.
4. Once the screws or bolts are removed, gently lift the gas tank away from the blower. Be cautious not to spill any fuel.
5. If there are any fuel lines or connections attached to the tank, disconnect them carefully by loosening the clamps or fittings.
6. Once all connections are detached, the gas tank should be free to remove completely.
Please note that specific models may have slight variations in the removal process, so consulting the Poulan Pro PPBP30/30cc gas backpack blower's user manual for detailed instructions is recommended.
11/19/2023 12:08:03 PM • Poulan Garden • Answered on Nov 19, 2023
My poulan pro riding lawn mower was cutting fine then I needed to reverse so I disengaged the blade, reversed, and once I was ready to go again, the second I tried to engage the blade, it died.
Engine kill when PTO engaged is an operator not in seat. Check/test the operation of the seat switch.
8/17/2023 10:02:13 AM • Poulan Garden • Answered on Aug 17, 2023
Can I add a bag and extras for a poulan push lawnmower model 961120080 00?
go online or to a place by you and order a kit
7/26/2023 11:37:55 PM • Poulan Garden • Answered on Jul 26, 2023
2answers
Poulan pro pp19a42 riding mower. Keeps getting slower and slower while going forward.and have pedal pushed all the way forward.
Junk plastic CVT transmission likely needs a repair kit. Minimum $125 for the kit and $100 labor for trans remove, repair, reinstall.
Check for grass clippings and debris on top of transmission but likely the damage has already been done.
6/23/2023 11:54:18 PM • Poulan Garden • Answered on Jun 23, 2023
Why will my Poulan Pro PO16542LT riding mower only go forward and backwards when clutch is engaged but when clutch is released it stops moving?
It sounds like there may be an issue with the drive belt on your Poulan Pro PO16542LT riding mower. When you engage the clutch, the belt tightens and provides power to the wheels, allowing the mower to move forward or backward. When you release the clutch, the belt should become loose and the mower should stop moving. If the belt is loose or damaged, it may not be providing enough power to the wheels when the clutch is engaged. This could cause the mower to move slowly or not at all. When you release the clutch, the belt may not be loose enough to completely disengage from the wheels, which could cause the mower to continue moving slowly or even stall. To check the drive belt, you'll need to consult the owner's manual for your specific model of mower. The manual should provide instructions for inspecting and replacing the belt if necessary. Alternatively, you may want to take the mower to a professional for repairs if you're not comfortable working on it yourself.
4/12/2023 3:31:39 PM • Poulan Garden • Answered on Apr 12, 2023
What is the compression of a Poulan pro 405 plus chainsaw?
a compression reading of between 110 to 130 PSI
2/19/2023 7:25:26 PM • Poulan Garden • Answered on Feb 19, 2023
2answers
I have a 2004 Poulan Pro PBV200 leaf blower, and have purchased a new ignition coil. My question is, how do I install it?
you have to pull the whole unit apart air gap is important so note the gap on the coil before undoing the old one exploded views Poulan PBV200 Pro Leaf Blower Parts you tube link Poulan pro leaf blower no spark POULAN PRO PBV200 INSTRUCTION MANUAL Pdf Download.www.manualslib.com > Brands > Poulan Pro Manuals > Blower > PBV200
1/25/2023 9:21:46 PM • Poulan Garden • Answered on Jan 25, 2023
Can i put 24 inch guide bar on 16" poulan P3416 34cc model?
you can but most likely will not cut to much the additional 8" will bog down engine and or cause clutch slippage
1/2/2023 4:11:28 PM • Poulan Garden • Answered on Jan 02, 2023
Does a poulan woodshark chainsaw have points
Looks looks like CDI. Older models like the Pioneer have points. https://www.ereplacementparts.com/poulan-p3314-type-gas-chainsaw-parts-c-16962_17147_17783.html ..
11/17/2022 5:04:07 AM • Poulan Garden • Answered on Nov 17, 2022
My Poulan Pro PP19A42 will not move. It is acting as if the parking brake in on, it starts and the blades in engage. The brake won't compress and the parking brake handle will not move.
Usually there is a spring involved that is held open in the normal position. This way if the spring breaks, or something fails in the brake mechanism, the brake will engage. Can you see if the spring has broken or stretched?
8/15/2022 5:41:54 PM • Poulan Garden • Answered on Aug 15, 2022
Poulan PR25 PoleSaw will not run full throttle
remove muffler and check spark arrestor screen.
8/14/2022 8:18:08 PM • Poulan Garden • Answered on Aug 14, 2022
Poulan 2150 Chainsaw. What is the correct ignition module for it please?
Question edited for clarity, (stuff in the right order). Available on Amazon from this link for $19. https://www.google.com/search?q=poulan+2150+chainsaw+replacement+ignition+module ..
7/10/2022 6:05:17 PM • Poulan Garden • Answered on Jul 10, 2022
Poulan WEEDEATER FEATHER LITE 1500 GAS BLOWER- Reconditioned Logo
3 questions posted
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
spool cutting wire
  • Garden
