20 Most Recent
Makita BHX2500 24.5 cc Blower Questions & Answers
Cuts out
thermal problem > sparkplug or ignition coil > fuel hose> or tank airiation.
Changing fuel line for bhx2500 blower
i put a stiff wire threw the hole and out threw the filler cap hole cut the end of the new line down to 1'3 about a 1/2'' long slide it over the wire and slowly pull the wire back when the hose sticks out remove the wire pull the hose tight put the filter on the end of the hose pull into position and trim to size
Have makita demo saw with auto decompression but will not decompress when trying to start
If your Makita demo saw has an auto decompression feature but is not decompressing when attempting to start, there could be a few potential causes for this issue. Here are a few things you can check:
- Check that the decompression valve is functioning properly. It could be clogged or stuck and not allow the engine to decompress.
- Check the air filter. A dirty air filter can restrict airflow to the engine, making it difficult for the saw to start. Clean or replace the air filter as needed.
- Check the spark plug. A fouled or worn spark plug can also make it difficult for the saw to start. Clean or replace the spark plug as needed.
- Check the fuel filter. A clogged fuel filter can restrict fuel flow to the engine, making it difficult for the saw to start. Clean or replace the fuel filter as needed.
- Check the carburetor. A dirty or clogged carburetor can restrict airflow and fuel flow to the engine, making it difficult for the saw to start. Clean or rebuild the carburetor as needed.
- Check the fuel level. If the saw runs out of fuel, it will not start. Make sure the fuel tank is filled with fresh fuel.
It's worth mentioning that if the saw is still under warranty, it is best to contact Makita's customer service and ask for assistance.
If you are not comfortable working with the engine, it is best to consult a professional or refer to the service manual for your specific saw.
