20 Most Recent Kenmore Refridgerator Air Flow Diffuser Part W10151374 Questions & Answers
Small fridge no fan /freezer works but fridge doent cool
Unless the fan works there will not be any flow to the fridge section as the cooling comes from the freezer coils. check the fan and replace after checking the power to the fan.
1/31/2013 10:33:21 AM • Kenmore... • Answered on Jan 31, 2013
I havev a kenmore coldspot model number 1052752100 freezer is cold but fridge doesnt stay cool
You will need to replace the air flow diffuser. Here is a link to the part you need.
10/16/2012 10:19:30 PM • Kenmore... • Answered on Oct 16, 2012
What is the cubic feet of 2009 Kenmore Coldspot refrigerator model 106.58909802.
Coldspot 106. Model This model refrigerator is a relatively small refrigerator. It is a Freezer on top model, and Sears documents lists this unit at 18.1 cu ft. I hope that answers your question about capacity. I'm glad I could help. If you need anything else, just let me know. In reality, when you buy a replacement, you buy by dimensions to fit the space not cubic feet of the old one. Go to Home Depot armed with a tape measure. ..
4/19/2024 6:36:40 PM • Kenmore... • Answered on Apr 19, 2024
2answers
Coldspot 106.51133210. How can I select diagnostic mode?
air damper motor control has failed , call a local repair service
4/13/2024 4:57:12 PM • Kenmore... • Answered on Apr 13, 2024
What is the cubic feet of kenmore coldspot model 106.59599993
The Kenmore Coldspot 106 is a 20.7-cubic foot side-by-side refrigerator with a reverse osmosis Pure water filter, ice maker and digital controls. ..
4/10/2024 12:02:42 AM • Kenmore... • Answered on Apr 10, 2024
Kenmore Refrigerator 795.75004401. The freezer seems to be working fine but the fridge part is not. Checked the condenser coils and they are free of dust. The condenser fan is working as well.
Turn it off by removing the wall plug for 10 minutes. This will do a power rest to the control electronics. This is a bottom mounted freezer, so cold air for the fridge is vented upwards by a fan. Make sure it is running and there are no ice blockages. Strangely they call the fan in the fridge an Refrigerator Evaporator Fan Motor. The part is obsolete anyway. If it normally says 4 for the fridge, that would be 4 degrees Centigrade, which means the freezer should show minus 18'C. Or 36'F Fridge / 0' F Freezer/ This shows all the parts. https://www.searspartsdirect.com/model/3tradtge4f-000582/kenmore-79575004401-bottom-mount-refrigerator-parts ..
4/7/2024 5:30:26 PM • Kenmore... • Answered on Apr 07, 2024
Kenmore model 790 9031 purchased 12/12. Oven shows F-10 error message?
Dangerous temperature runaway.
How to Fix the Kenmore Oven F10 Error
PartSelect https://www.partselect.com > blog > kenmore-oven-f10... Nov 3, 2023 - An F10 error on a Kenmore oven means that it is sensing a runaway temperature. This walkthrough outlines the symptoms, causes, and solutions ... Missing: 9031 ‎' Show results with: 9031
Troubleshooting an F10 error code on a range video
Sears PartsDirect https://www.searspartsdirect.com > diy > article > troubl... Jan 18, 2016 - If you see F10 on your range, it means that your electronic control board has detected a runaway temperature. It's possible that your range ... Missing: 9031 ‎' Show results with: 9031 ..
4/2/2024 3:38:27 AM • Kenmore... • Answered on Apr 02, 2024
What are the specs on Kenmore fridge model 253.7419240. How many cubic feet please.
kenmore model 253 refrigerator cubic feet
Sears https://www.sears.com > search=kenmore model 253 refr... Side By Side Refrigerator With 28 Cubic Feet Capacity External Water Dispenser Only Feature Option Standard Depth and 36" Width. Sold by Appliance Dealz.
3/28/2024 5:19:28 AM • Kenmore... • Answered on Mar 28, 2024
I have a Kenmore Refridgerator model 45241, 55241. How old is it?
I have one also mine is a 1992 build year
3/10/2024 1:19:57 AM • Kenmore... • Answered on Mar 10, 2024
Kenmore Coldspot 1069555721 cubic feet?
Total volume: 21.9 cu. ft.Refrigerator volume: 14.5 cu. ft.Freezer Volume: 7.4 cu. ft.Height without hinge: 65 7/9 in.Height with hinge: 66 3/4 in.Depth without handle: 32 1/8 in.Depth with handle: 33 7/9 in.Max. depth with doors/drawer open: 49 7/8 in.Width: 32 3/4 in.Clearance- Additional width required to open the doors 90?°Door edge: 3/4 in.Handle: 2 5/8 in. https://www.google.com/search?q=Kenmore+Coldspot+1069555721+cubic+feet ..
2/20/2024 8:56:46 PM • Kenmore... • Answered on Feb 20, 2024
2answers
Is there a flapper at the bottom of the defrost line that can get plugged. it's a Kenmore Coldspot. What else can I use other than hot water to clear the drain.
Not normally a flapper. There is a trap on the rear outside cabinet just below the level of the freezer. Remove it and soak in hot water and bleach for 20 minutes, then flush all the debris out, shake it dry and reinstall. ..
2/18/2024 7:29:43 PM • Kenmore... • Answered on Feb 18, 2024
My Kenmore freezer model number 253-928-4013 was made in May 1999. What cubic foot size is it?
18 cubic feet by popular belief and the third number after the 253 series number.https://www.google.com/search?q=Kenmore+freezer+model+number+253.9284013+specswith a chest freezer it is just as easy to multiply it out...
2/7/2024 9:54:46 PM • Kenmore... • Answered on Feb 07, 2024
I can't get my ice maker water filter to turn and lock in place
Put some Vaseline on the O-Ring to help it slide into place. Make sure it is properly inserted at the beginning. If the filter is located inside the refrigerator:
  1. Turn off the ice maker.
  2. Push the eject button.
  3. Pull the filter out of the housing.
  4. Push the new filter into the housing until it clicks.
  5. Turn on the ice maker.
  6. Run 2 gallons of water through the water dispenser to purge air and residue.
More items... • Aug 30, 2023
How to replace the water filter in a Kenmore Refrigerator
1/28/2024 2:40:53 AM • Kenmore... • Answered on Jan 28, 2024
What is cubic feet of Kenmore Refrigerator model # 253.53624300 just need cubic feet size
253. Range 16.5 cu. ft.
Kenmore 253 Use & Care Manual
ManualsLib https://www.manualslib.com > ... > Elite 253 Series Refrigerator Kenmore 7472 - 16.5 cu. Ft. Top Freezer Refrigerator Use ...
1/18/2024 1:05:52 AM • Kenmore... • Answered on Jan 18, 2024
What is the cubic feet inside of the kenmore refrigerator 10674254400?
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller). I hope this helps. Cindy Wells From here on Fixya https://www.fixya.com/support/t26563238-many_cubic_feet_kenmore_coldspot ..
1/17/2024 8:58:50 PM • Kenmore... • Answered on Jan 17, 2024
Thanks so much for answering my question on my Kenmore Coldspot Refrigerator Model 10674254400! You said it was 22 cu ft. Is that the total cu ft. for both the freezer and the refrigerator.
Hello Linda. This should be below my Answer rather than being a new Question. This post has no context to the previous question and my answer. I just happened to see it, but if you clicked Comment under my answer, I would get a notification and come back to help. If I hadn't seen it and someone had answered it with 'not sure what you mean', it would have vanished off the Homepage as Solved and I would never have seen it. I was just copying Cindy Wells answer, but yes, it is the total cubic feet of both the refrigerator and freezer combined. https://www.fixya.com/users/linda-adamski ..
1/17/2024 8:56:29 PM • Kenmore... • Answered on Jan 17, 2024
Kenmore Refridgerator Air Flow Diffuser Part W10151374 Logo
7 questions posted
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
small fridge no fan freezer works but
  • Refrigerators
