20 Most Recent
HP Compaq Presario v4000 Notebook Questions & Answers
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
3/22/2017 2:57:32 PM •
HP Compaq...
Answered
on Mar 22, 2017
Unable to charge computer. I plug it in but it
There are two possible reasons for this. The first is a bad power cable, the second is a bad power supply. A cable can usually be replaced on the cheap, but if it is the power supply, it will cost a bit more. Unfortunately, the only way to be sure is to try another power cable, which can be hard to find without buying.
3/14/2011 11:53:17 PM •
HP Compaq...
Answered
on Mar 14, 2011
Would a compaq presario v2000 screen be compatible
Its not compatible. It has different screw listings then V4000.
If you could provide me the product No. which is at the bottom sticker of the notebook of your Compaq v4000 laptop then I can find the part no. for LCD screen which is less costlier and exchangeable.
5/31/2010 9:52:39 PM •
HP Compaq...
Answered
on May 31, 2010
My Compaq laptop will not boot up. It gets only
Tturn on your computer, then, before the windows boot screen appears, press the F8 key, this should bring up the start options , if it does not, turn off , turn back on and try again.
On the start options use the up/down arrows on keyboard to select "last known good configuration", press the enter key. Windows should start as normal if it does not do the process again but instead select "safemode" .
10/19/2009 12:16:37 PM •
HP Compaq...
Answered
on Oct 19, 2009
Were can i get drivers for my compaq presario
On Following link you can download Driver for your Laptop.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=461884&lang=en&cc=us&prodTypeId=321957&prodSeriesId=434656&taskId=135
Thanks.
10/14/2009 11:24:08 AM •
HP Compaq...
Answered
on Oct 14, 2009
My dvd/cd rom is not responding. it is not even
First check if it is getting proper power. When you turn on the computer, do you see a blinking light on the Drive. Kindly check if the device is found in the BIOS, If it is not detected in the BIOS possibly check the data cable. If you have more than 1 drive make sure the jumper settings are correct.
10/3/2009 6:11:56 PM •
HP Compaq...
Answered
on Oct 03, 2009
Firewall
Go into your bios and, remove the passwords...if you don't know the passwords unplug your battery,then:your powersupply and, the little bios battery on your motherboard wait 10 minutes then restart
8/26/2009 1:40:17 AM •
HP Compaq...
Answered
on Aug 26, 2009
No picture
If you mean you hooked up an external monitor and you want to see the display there. Well there should be a Fn key combo to toggle the displays. It should be one of the keys that looks like a monitor plus the Fn key at the same time. Otherwise go into the Control Panel -> Display -> Settings and you can switch to the other monitor there. Hope this helps.
6/15/2009 2:19:07 PM •
HP Compaq...
Answered
on Jun 15, 2009
I need drivers for my compaq hp presario v4000
Hello, you might want to visit the manufacturer's website, normally this is the best solution if they have them available, other option is if you can access the internet, to go to one of the free computer webased scanners, I been a tech for many years since the (Vic-20) came out and I have found that the guys at
www.driveragent.com have one of the best ones, it will do a scan on your computer and give you a list of compatible drivers, I use it all the time, to actually be able to download they will have a fee, as many others, hope that little bit of info helps you some.
5/9/2009 9:06:48 PM •
HP Compaq...
Answered
on May 09, 2009
Where can I find heatsink repair kit for compaq
if you are not a computer tech, don't try to repair the hearsink on your own. Heatsinks are 10 dollars thru 30 dollars and most repair shops will charge only about $25 to install it. You won't reget it, you can let the pros do their work or you might blow your motherboard or other devices, trying to do it yourself
5/9/2009 3:13:54 PM •
HP Compaq...
Answered
on May 09, 2009
