20 Most Recent HP Pavilion ze4560us Notebook Questions & Answers
Power led continuously changes between green
you cant do that. tell me how to test a MOBO charger CHIP with no battery nor a shorted ,dead or faulting battery.??? you can't . does PC run on line power (yes/no)? why not state that first. battery OUT. this is test one on all battery powered PCs battery out test. never seen any 6 year old battery good, it be like world record that. so 15bucks too much to get it on battery, do you even need a battery? (I do for travel only) do you. then why travel with a 6 year old battery knowing full well it will fail just when you need it most,, why do that? as one small example. in any case , the battery is not even sold in your town. most are not. and takes week to get one. in most cases (vast types exit) do be aware the pc can run perfect on a/c and not even with a new good battery if the chip charger fails, as they sure can. and is near impossible to get that very tiny solderball chip out. and 10x harder back in, need photos? have them doing it. using spec. equipment.
5/30/2017 4:05:48 PM • HP Pavilion... • Answered on May 30, 2017
Cant remember the password to boot
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password
2/25/2013 12:13:54 AM • HP Pavilion... • Answered on Feb 25, 2013
0answers
2answers
I changed to hard drive
ok to rare but try to make a two partitions , when you install xp shows an partition option , make one partitions to 40gb and the other 120 gb and try , yo can do this form windows but be sure that you have all your documents save like backup , many programs on line you can find on line for do this , just search in google, a program that i recomend is partition magic easy to use
8/11/2010 2:58:20 PM • HP Pavilion... • Answered on Aug 11, 2010
2answers
When adding memory must u add 2@ 512mb or can u
http://www.crucial.com/store/listparts.aspx?model=Pavilion%20ze4560us
You can put memory in one or both slots, max is 512Mb Per slot total 1Gb
12/20/2009 4:53:30 AM • HP Pavilion... • Answered on Dec 20, 2009
What is the Disk Interface on the ze4560us model?
u mean the hard disk interface? it should be a pata connetion
7/30/2009 9:36:31 PM • HP Pavilion... • Answered on Jul 30, 2009
RAM Upgrade HP ZE4560
Here are the specs for the memory in your system.
Memory Type
DDR-266 (PC-2100) SODIMM
Format
200-pin SODIMM
Latency
2.5-3-3-6
Maximum Memory » 1024 MB
Is this what you bought? If not take it back and get memory that matches the specs above.
6/17/2009 9:15:31 PM • HP Pavilion... • Answered on Jun 17, 2009
Hp pavilion ze4560us processor slow
Probably what you should do first is download Malware Bytes and do a quick scan/clean of your system to make sure there is no malicious code on it.
Beyond that (if the machine tests clean) post your results and/or a list of the processes that are running so that we can further assist. Also, if you are currently running any anitivirus programs please post what kind.
4/3/2009 2:07:38 PM • HP Pavilion... • Answered on Apr 03, 2009
Turn back on the double click on touchpad of laptop
go to device settings, properties, tapping, then check the box.
2/12/2009 2:54:54 PM • HP Pavilion... • Answered on Feb 12, 2009
No power to the computer
Check this link:
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
1/30/2009 3:22:28 AM • HP Pavilion... • Answered on Jan 30, 2009
Usb 2.0 on pavilion ze4560us
This computer only has a USB1.1 support, this is the complete specs for this computer check this link http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00249077&dlc=en
10/21/2008 2:50:20 AM • HP Pavilion... • Answered on Oct 21, 2008
Pavillion ze4560us
dude usb 2.0 was released way back... i believe the necessary drivers have not been installed... you better go to device manager and try updating the drivers... it would have option to check online... post here if u need more help...
10/18/2008 4:04:56 PM • HP Pavilion... • Answered on Oct 18, 2008
Cannot find wireless adapter
here are your drivers for that particular model
Driver - Network Date Version Previous Size » Broadcom WLAN Network Adapters Driver for Windows XP 08-2004 3.00 B » Version: 3.31M » Broadcom WLAN Network Adapters User Interface 06-2004 2.00 B » Version: 16.44M » National Semiconductor DP83815/816 10/100 MacPhyter NDIS 5.0 Miniport Driver for Windows 2000/XP 10-2003 1.00 C » Version: 5.68M
10/6/2008 3:42:53 PM • HP Pavilion... • Answered on Oct 06, 2008
2answers
Pavilion ze4560us laptop touch Pad
  • Click "Start"
  • Click "Control Panel"
  • Double Click "Mouse"
That will bring up all of the settings for th emouse/touchpad...the option to turn off the tapping should be in there!
10/6/2008 3:38:28 PM • HP Pavilion... • Answered on Oct 06, 2008
Recovery of data
Soo.... You push the power button and WHAT happens?
2/16/2008 10:32:34 PM • HP Pavilion... • Answered on Feb 16, 2008
Data Recovery
try Tigerdirect for your cable.
10/22/2007 1:54:01 AM • HP Pavilion... • Answered on Oct 22, 2007
I have email error 99999
delete and reinstall your email software.
6/25/2023 8:52:09 PM • HP Pavilion... • Answered on Jun 25, 2023
HP Pavilion ze4560us Notebook Logo
Popular Tags
21 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
changed hard drive
  • Computers & Internet
