20 Most Recent
Husqvarna 125B Blower Questions & Answers
I need to know the starting point and how may
Both screws start at 1 turn out....Adjust High speed till it 4strokes and 2 strokes usually 1/8 turn either way....then adjust idle so it revs staight up...should be same 1/8 turn either way from start...if it is more carby will need overhauling..
I need clearance specs for the coil and flywheel
This isn't the most technical sounding answer but it works and I've used it numerous times with no problems. To set the coil gap on small 2 cycle equipment , I use a 3" x 5" note card, tighten the bolts then manually turn the flywheel to make sure it doesn't rub.
Where to get rings for Husqvarna 145bt?
The problem is that the engine is a funny size at 40cc. If it was 50cc, you could get away with motorcycle rings. The normal way to size rings is by measuring the bore with an inside micrometer across left to right and then again front to back. The front to back measurement is often a little more worn. Then you order rings by diameter and thickness, Any local engineering company can do this and supply you with generic rings.
There is a different model here with rings at $25 but Jack's Small Engines is $57. My advice is get the OEM ones. You will also need to hone the bore lightly to dull the polish. Oil the new rings with 2 stroke oil when fitting them.
https://www.google.com/search?q=husqvarna+145bt+piston+rings+size
