20 Most Recent Husqvarna 223L Questions & Answers
What could cause the trimmer to shut off affter running for 15 to 20 mins as if you just hit killed switch??
That\'s what\'s know as coil heat soak. Inside a transistorized coil pack which is what you have that makes the spark happen, there is a small circuit board with diodes and stuff. Sometimes one will go bad from time or use, usually hard use, and when it fails, the engine will run a while then reaching a certain temperature, the diode will kill the coil as if you had hit the kills witch and stop the spark. The aluminum of the engine dissipates heat quickly which is a reason why engines are made with that material, and thus will restart after a few minutes as if nothing happened. You need to replace the coil. There is something further, if the breather built into the gas cap or gas tank gets clogged or becomes inoperable, the vacuum created by the fuel system that allows the fuel to continuously be sucked into the carb and engine will have no way to replace the negative space created by the missing fuel in the tank with air, so it will essentially choke itself to death and the engine will shut off and not start until you open the gas cap and let in some pressure to equalize the vacuum. But that\'s slow and you can feel it happening like the machine is running out of fuel, the heat soaked coil is immediate just like switching the I/O button which is basically what\'s really happening. Hope this helped you.
9/12/2014 6:40:49 PM • Husqvarna 223L • Answered on Sep 12, 2014
Husqvarna 223L won't start
I would first take the spark plug out and see if the tip is wet, it could very well be flooded. second of all I'd try putting fuel directly into the carb (if this helps you'll most likely need a carb kit or maybe even a new carb)
7/23/2014 1:09:46 AM • Husqvarna 223L • Answered on Jul 23, 2014
I need instuctions on how to put back the throttle assemble for a husqvarner 223L trimmer
Hello Ronny I'm not fully familiar with that model however I have found a diagram that may help you. The image is a little small but it may give you an idea of the springs location. 8eb2bb1f-cbaa-46fb-af4d-ba25b0099562.jpg
6/7/2014 11:32:11 AM • Husqvarna 223L • Answered on Jun 07, 2014
0answers
How do you fix pull cord
you have to disassemble the pulling mechanism and take the old cord out and replace with a new one. I suggest applying a bit of silicone oil over the new cord.
4/23/2014 2:26:20 PM • Husqvarna 223L • Answered on Apr 23, 2014
0answers
Nut
Be the first to answer 4/22/2014 3:55:45 AM • Husqvarna 223L • Posted on Apr 22, 2014Be the first to answer
0answers
How to replace throttle cable fpr husqvarna 223 l
Ill send you the IPL
8/2/2013 1:15:09 PM • Husqvarna 223L • Answered on Aug 02, 2013
New husqavarna head wont turn
Will spin or wont spin.? Slight confusion in your question.
8/2/2013 1:12:09 PM • Husqvarna 223L • Answered on Aug 02, 2013
Bump head wears out very fast on husqvarna 223L
Are you resting the head on the floor while strimming and wearing out the bumpcap? Are you hitting it too hard on the floor when you want it to feed out.? Are you using the full harness or the strap harness when using it.? Either way it should be set the the correct length, so the strimmer is just off the floor, i like to have it so the front tilts down, that way it would keep the bumper off the floor. Either way thay should last way longer then 2 weeks so i put it down to opperator error.
8/2/2013 1:03:06 PM • Husqvarna 223L • Answered on Aug 02, 2013
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
7/30/2013 11:24:31 PM • Husqvarna 223L • Answered on Jul 30, 2013
To much gas after replacing primer bulb
The lines can only go on 2 different ways, if the primer bulb is filling them im guessing its the corrrect way. However your friend may have tried adjusting the carb before he gave it to you. I'd be looking at carb settings or a sticking needle.
7/30/2013 11:22:58 PM • Husqvarna 223L • Answered on Jul 30, 2013
Why won't my Husqvrana 223L trimmer crank?
Electrolux products are junk, should have bought a stihl.
7/4/2013 3:28:27 AM • Husqvarna 223L • Answered on Jul 04, 2013
0answers
Husqvarna 223l starts but quits before I can even get the choke off, then will not even start again. Has been great until this.
I can assure you it wont be leaking oil, as the only oil it uses is mixed with the fuel.Lock throttle trigger on,Start on full choke till it fires, Switch to half choke and it should fire up on high revs,Blip the throttle and it should turn to tick over.If it still keeps cutting out it could point to a carb or fuel takn issue.
3/4/2013 10:42:03 PM • Husqvarna 223L • Answered on Mar 04, 2013
Need assembly instructions for handle controls for 223L
3/4/2013 10:37:46 PM • Husqvarna 223L • Answered on Mar 04, 2013
Husqvarna 223L Logo
22 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
could cause trimmer shut off affter
  • Garden
