20 Most Recent
Husqvarna Ignition Coil 55 257 245 51 254 50 51 240 262 40 45 506027207 Questions & Answers
How do I adjust the air gap on aignition coil on a husqvarna 240 chainsaw
Use an air gap tool. Clean the area where the coil mounts on the engine with emory cloth to make sure you get a good ground. install the coil and lightly tighten screws (just over finger tight) slide in the air gap tool and align the coil, make sure both legs of the coil are even on the tool. Snug the screws and recheck the gap.
2/3/2016 6:47:45 PM •
Husqvarna...
Answered
on Feb 03, 2016
HOW TO SET CHAINSAW TIMING
There is not a method to set timing. The flywheel is keyed for location. The ignition module can be moved slightly but the effect will be minimum. If you are having backfires or think timing is wrong. Check the key and make sure it is not sheared.
4/27/2015 8:29:09 PM •
Husqvarna...
Answered
on Apr 27, 2015
45 coil setting
The air gap between the unit and the flywheel should be 0.3mm for the Husqvarna 45
10/16/2012 7:20:37 PM •
Husqvarna...
Answered
on Oct 16, 2012
