20 Most Recent
Husqvarna 36 41 50 51 55 136 141 154 254 257 261 262 Oil Cap Aftermarket Questions & Answers
Husqvarna 141 clogged fuel vent
The breather is made of a sintered brass plug and beneath this ia what i call a duck bill valve ( because it looks like a ducks bill ) this is a one way valve green in colour which allows air one way into the tank, to test correctly you should do a vacume test via the fuel hose, to remove the valve will normally destroy.
Carberator adjusting
Many new units have a very limited adjustment possibility. This is due to EPA regulations. If the saw is hard to start, it may need to be richened up a little. Your dealer should have proper tool to adjust.
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
My husqvarna 141 will not start??
Very unlikley to be an air lock, more likley to be a massive air leak, check the rubber induction tbe behind the carb mount it may have split, if not then a possible blown crank seal.
Chain oil leakage
If its leaking straight out then its not a problem with the pump. The problem lies in the fact that its not making it to the pump, hence the leak. Now depending on the model the pump is often linked to the oil line via a little gromet. Check these parts all link up correctly and nothing has got damaged.The picture shows the oil pump assembly on a Husqvarna 254
Chain oil leakage
To help you more please give us the model of your Husqvarna machine.
