The latest DA230-3 hood is a 120V 15amp model and has a black/red wire to live, a white wire to neutral and a green to ground.
You may have a 220V model. I suggest to have a licensed electrician hard wire according to the voltage, load, and circuit rating listed on this data plate.
The 2 black wires on the hood go to the black from the wall. The 2 black on the hood is in case you want separate switches as 1 is for fan and 1 is for light. The green goes to the bare copper wire. Its the ground. And are you sure the wire is yellow? It should be white and connect to the other white. This is the neutral.
Try this........Please use the following sequence to clear the "cleaning lock" mode.
1. Switch the appliance off.
2. Touch pad Clear and hold.
3. Release pad Clear.
4. Touch pad Clear 5 times and at the 5th time, hold it until the programming mode appears.Programming.
This must be completed within 10 seconds or it will not work.
You should get an acknowlegment indicator. The display shows the positions of the programming mode Programming.
1. Touch the pad next to Reset Cleaning
2. Select yes
The cleaning lock should be lifted.
3. Select touch pad on/off
I have just given mine yet another thump with my fist on the stuck side and this time it slid backwards. I promised it that I would be more gentle in pulling it out in future.
Is it a new or existing installation? If new, check it has been pluged in and switched on. Don't laugh. Not uncommon with chippies installing them. Otherwise prob the power board.
