20 Most Recent
Electrolux Stainless Steel Induction Slide In Double Oven Range Ew30is65js Questions & Answers
What is signification error code 15
Good Afternoon Friend,
I understand you are receiving an Error Code 15 on your Electrolux range, model# EW30IS65JS, and want to know what it means. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and Start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number, so I am able to better assist. Hope this is helpful.
-Best Regards-
WP
Electrolux ew301s6cjsa
Not enough info and I dont have that code. But, there are thermal safety devices in back of the ovens that can shut everything down. Unless your electrically quailifed, find someone who is and has a meter, then pull oven(s) out of the wall and check all safety devices... If you need further help, reach me via phone at
https://www.6ya.com/expert/steve_24d988f3507f7480
Electrolux wine cooler R134a door sensor
I don't see any door switch or sensor in the electrical diagram; maybe it's mounted on one of the circuit boards and is operated by a mechanical actuator. On most refrigerators, that's near the top of the door.
From what you describe, maybe you should check for a warped door or a loose, bent or worn door hinge.
Water not going to ice maker of electrolux icon no power to water inlet valve
If your Electrolux Icon ice maker is not receiving water and there is no power going to the water inlet valve, there are several possible causes:
- Faulty water inlet valve: The water inlet valve is responsible for controlling the flow of water into the ice maker. If it's faulty, it may not be opening to allow water to enter the ice maker. You can check the valve for continuity with a multimeter to determine if it's faulty.
- Frozen water line: If the water line leading to the ice maker is frozen, it may prevent water from reaching the ice maker. You can thaw the water line by turning off the power to the refrigerator and allowing it to thaw naturally or using a hair dryer to gently thaw the line.
- Faulty ice maker: If the ice maker is not sending the signal to the water inlet valve to open, it may be faulty. You can test the ice maker by manually advancing it to see if it completes a cycle and sends the signal to the water inlet valve.
- Wiring or control board issue: If there is no power going to the water inlet valve, there may be a wiring issue or a problem with the control board. You can test the wiring for continuity and check the control board for any visible signs of damage or burning.
If you're unsure how to proceed, it's recommended to consult a qualified appliance repair technician to diagnose and repair the issue.
Electrolux plhs268zcb1 fridge too cold
please lower the temperature of the fridge as well and check if the freezing on the side stops. Otherwise, you can rub some salt on the ice to unfreeze that section if you'd like to do that.
Thank you.
My Electrolux fridge is collecting water under the trays. No visible drain.
Every fridge has a drain usually on the back wall bottom left inside the fridge; just above the compressor.
Without a drian there is no where for the condensation to go except under the drawers on under the food trays.
It does not look like a drain but it is there.
Some Electrolux refrigerators have a visible drain hole on the rear wall or behind the wall's access panel. In this case, you can flush the hole with hot water to dispel the blockage.
No power to Electrolux ESE6077SC side by side fridge freezer (a small white light flashes every 20 secs or so from the door water & ice dispenser though)
Hello - Sounds like the power outage possibly caused a communication problem with the control board to the refrigerator not responding. From what you explained in your comment, if the refrigerator seems dead I would strongly suggest contacting a professional to move forward accurately. If the unit is not cooling in either section of the appliance, unit can be experiencing some form of sealed system issue as well. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact you're a professional to properly diagnose the refrigerator.
What do the symbols SY and CF on a Electrolux fridge door mean?
5Y CF indicates a communication error between the refrigerator control board and the user interface (display panel). When the refrigerator was powered up, its self-test didn't complete properly. The wiring harness, the user interface or the main control board could have damage. Make sure that all of the wiring connections are fully seated first and then check the individual wires for continuity. Then you have to check the user interface and main control board by testing and replacing them. If your refrigerator is under warranty, get Electrolux to send a technician to test the refrigerator.
I hope this helps. I may be able to find a parts diagram if you add a comment with the model number of your refrigerator.
