20 Most Recent
HP PSC 1210v All-In-One InkJet Printer Questions & Answers
Was given printer downloaded software but no idea
WHEN YOU PLUG IN YOUR COMPUTER AND CONNECT IT TO YOUR PC , IT SHOULD AUTOMATICALLY DETECT YOUR PRINTER, AND WHAT TYPE AND MODEL THE PRINTER IS. iF YOUR COMPUTER DOES NOT RECOGNISE YOUR PRINTER OPEN YOUR CONTROL PANEL UNDER THE START MENU, AND THEN GO TO PRINTER AND OTHER HARDWARE. iF YOUR PRINTER MODEL ISN'T SHOWN GO TO ADD NEW HARDWARE OR PRINTER AND CHOOSE YOUR BRAND AND MODEL NUMBER AND WINDOWS WILL SEARCH FOR YOUR PRINTER ONLINE. oR YOU CAN GO DIRECTLY TO YOUR PRINTER WEBSIGHT EXAMPLE, HP.COM OR BROTHER PRINTERS .COM ETC. AND UNDER SUPPORT SECTION YOU CAN FIND INFO THERE.
I have a hp psc
1 Installing printer software when power on printer
2 then connect printer usb cable
3 automayically found drivers after finish restarting system OK
I don't have
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=90763&taskId=135
My printer bkeeps showing offline & won't
Sometimes a printer will go to work offline and not realize its still offline when you turn printer back on.
If you can see a printer icon in your tray (bottom right) then double click it and you see a windows similar to the one screen shot below and click on "printer" menu and uncheck "use printer offline".
If that still doesn't work then delete the job in the queue and try to print again.
No cd to install and
Please go to :http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=90763&taskId=135
and download and install the drivers. Then the printer should work.
Hp director wont open
Try downloading the latest software,
1 Go to hp.com
2 Click on Support and Drivers
3 Enter your product name or number
4 Hit go
5 Choose your operating system
6 Hit Next
7 Click on the link that says Driver - Product Installation Software
8 Save it to your desktop
9 Double Click the icon on your desktop
10 CLick Extract
it should then run through it's installation process.
Just installed a 1200 all
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:---
" 1) Turn the printer on.2) The power on green light should be steady green,not blinking green.
3) When its steady green at that time.Press the cancel and color button both together.
4) By doing this the green light will flash,and printer will take the paper.
5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port.
Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Hello, and Happy Holidays!
Are you using Windows 7 or another older operating system? Are all of the updates installed for the operating system?
I would try to uninstall the printer, and let the computer find a driver when it is reconnected to the usb port with the printer turned on.
Good luck on getting your printer to work.
