20 Most Recent
HP DeskJet 722c InkJet Printer Questions & Answers
Print job stops in the middle of a print job
first if its happening from few days than go for system restore - start - all programs - accessories - system tools - system restore.. select that date on which it worked fine.. or else add printer and install deskjet 990c and than try
Reset an hp 722c printer
To reset your printer, unplug from wall and computer. Wait 1 minute. Done. That won't fix your problem. If it prints fine off word processor, the printer is fine. Need some setup for labels.
Inkjet printer disposal
Hi, You could either advertise it on an auction site for spares or your local shop.
You could advertise it "Free to collector" as spare only!!
If you didn't want to do either your local rubbish tip as they will take electrical appliances for no charge and if they can they will also recycle.
Here in the UK some charities will take un-wanted electrical appliances and will repair it or use parts to fix something else, they will then sell it on raising money for charity.
Or you could simply break it up and put it in the bin, with other household rubbish.
Hope this has give you a few ideas!!
Are there converter cables for a 722C deskjet printer that can be hooked up to a new computer with Windows 7?
I'm looking for one now, myself. I decided dig-out the HP 722C and try to get it work with Windows7 64-Bit, now that I see there's a driver patch for some of these older DeskJets. I already downloaded and applied the patch (See message thread in the HP forum).
I'm now shopping for a 36-Pin Centronics Male to USB-A (Male) cable converter. Be careful on the male Centronics plug - - - The one I'm looking for has 36 small square holes in the center. Do NOT just buy any coverter cable, as some people report they couldn't get it to work (with Win7 64-Bit). It must state it works with Win7 64-Bit or customer comments/reviews say it does.
There's another type of Centronics that has 36 contacts spaced closer together without the 36 square holes. I have that cable and it must have come from an old Epson dot-matrix printer I once had. It will not fit my HP 722C. I do have a DB-25 to Centronics (36-Pin) cable I got from RS years ago. Now I need to get the new cable.
I am installing a HP
Yes but do not turn it on. wait until you reach the step in the installation process that asks the printer to be turned on
I have a new Dell
Hp has not released the Windows 7 compatible drivers for Deskjet 722C.
There is workaround to this problem which is posted on HP support website. Click
here to read the detailed steps
Hope this solves your problem. Thanks for using FixYa.
Everything from laptop to printer seems to be
Try doing a self test by holding the paper feed button until the green light flashes. If it prints a test page then you should try a different printer cable. You can also clean the contact points on the cartridge (looks like gold dots) by using nail polish remover or surgical spirits.
