Apparently this is a very common issue with this printer. Some repair
people won't touch it and tell you to buy a new printer. However, I
have been able to find a solution to your problem. You need to clean
the scanner mirrors and the black ribbon under the cover.
*****CAUTION***** This is a very complicated project and can result in
the loss of your printer. So proceed VERY cautiously, or send it in
for repair.
Below are some instructions I have found to disassemble your printer.
Please remember, only do this at your own risk and use extreme caution
while doing so.
Here are the instructions:
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
HP LaserJet 3330 Scanner Unit
Disassembly Procedure
This is not an Hewlett
Packard
document, the author does not
work for Hewlett Packard and is not responsible for any damage you do to your
printer.
This procedure is for skilled
repair technicians and is not recommended without some knowledge of equipment
repair.
Proceed at your own risk.
- Open
the document feeder and pull up on the two black tabs on the left and
right.
- Pull
up on the right part of the doc feeder then the left, remove doc feeder,
set aside.
- Open
front door and rear fuser door.
- Remove
screws closest to teal colored fuser release levers. (side cover screws)
- Pull
right cover out from back while releasing clip on bottom of cover, pull
cover towards the back and remove.
- Push
on indentation at back of left cover and pull out at back, this cover is
hinged.
- Remove
four screws now visible at base of scanner assy., two on left two on
right.
- Slide
covers towards back and remove.
- Remove
two screws in the back just above the fuser and just below the scanner
assy. base. Remove two screws in
the front, visible now after removing the scanner assy. base covers on the
right and left (the left one is
just behind the hinged cover near the top hinge.)
- Remove
flat ribbon cable (on left side) at either connection point to disconnect
scanner assy. from print engine.
- Entire
scanner assembly can now be slid forward and removed.
- Close
the front, rear and left side doors on the print engine portion and set it
aside.
- Grab
front panel face plate at top and pull forward and remove. (or pry gently
at top of face plate).
- At top
of exposed front panel you will see four slots in the scanner assy. At the third one from the left there is
a latch (dark grey plastic). Push
down on the latch with a screwdriver and slide the whole panel assy. to
the right. Lift up and out making
sure to disconnect the cable.
- Remove
the three screws in the now exposed dark grey front panel cradle and
cover, remove the two cables connecting the cover to the main board, pry
gently at the top outer corners of the cover and pull it forward and down,
remove the cover.
- Now
remove the four scanner assy. screws (one and the center front, center
back, center right, center left) all are facing down under the assy. (Or
just flip it upside down and remove the four visible screws.
- Turn
the unit back upright and remove the four screws at the back/top (two of
them are down inside where the doc feeder normally goes.) Remove the top scanner cover position. Note: When putting the top cover back on double
check to make sure the scanner belt is not twisted.
- DANGER
your about to work on the scanner carriage itself there is a really good
chance that you could break it or the mirrors or bulb so proceed at your
own risk.
- At the
top and bottom left side of the black cover enclosing the mirrors are two
slots, if you put a small screwdriver in the slots and push gently to the
right and lift that side of the cover it should come loose. Then open it to the right and remove it
from the right slots.
- Remove
the black screw at the front of the assy., Disconnect the white wires from
the CCD board and out of the harness, lift the clear plastic bulb holder
out with the bulb then remove it from the rear. (it’s a tight fit at the
front.)
- The
top mirror is held in by some really tight clips they have to be removed
from the bottom right (clean the mirrors without this step if
possible). NOTE: optical mirrors
are not like a bathroom mirror, there is no glass covering the reflective
surface. The back side of the
mirror has glass covering it so if you get it in backwards it won’t
work. (The way to tell which side
you have is touch your screwdriver to the mirror and if it’s the right
side the screwdriver will appear to touch the reflection of the screwdriver,
if it’s the wrong side the screwdriver will not touch the reflection of
the screwdriver because of the glass covering the reflective surface.
- Now
clean the remaining mirrors and lens very thoroughly with alcohol. Make sure they are very clean. You can put the top mirror back and clean
it in place to make cleaning it easier.
- When
re-assembling the top cover check to make sure the white strip on the
right side is clean.
- Reverse
procedure for re-assembly.
