20 Most Recent
Stanley 61804n Professional Backpack Poly 4-gallon Sprayer Questions & Answers
Stanley 10-801 utility knife. How
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Stanley P1800S pressure washer lost pressure after a few uses
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
