20 Most Recent
HP OfficeJet d145 InkJet Printer Questions & Answers
Expired ink cartridge
You may be getting this error message due to the printer being able to tell that it is a non-hp cartridge. I don't know how it can tell, but mine says that too. I uninstalled the software and then reinstalled the software. And then I took out the cartridge and put it back in. See if this works for you.
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
I Have An HP D145
Most likely this is an issue with the way the website is displaying the coupon. Check to see if there is an option to print coupon. You might also try to create a PDF copy of the coupon and then printing the PDF document. Finally, one other thing you could try is to take a screen capture of the coupon, save as an image file or PDF and then print as an image or PDF. Hope this helps.
I guyz. my hp officejet
Hello
Before actually printing your report, use the Print Preview function to see how it will look. If there are blank pages, you will see them in Print Preview.
To use the Print Preview function, simply open the report, click on the "File" menu and choose "Print Preview" from the file menu. You will then see your report just as it will look on the printed page.
Scroll through the report for blank pages. If you see blank pages, it is an indication that the data on the report is wider than the paper you are using. You can use your printer properties to change the size of the paper if you wish. If you have access to legal-size paper, you may be able to print the report on the larger paper. If legal-size paper is not an option, you will need to adjust the margins so that the blank pages are eliminated.
To adjust the margins of your report, click on the "File" menu and choose "Page Setup" from the drop-down box. Go to the Margins tab and adjust the margins as needed. It may take a bit of experimentation to get the margins just right; toggling back and forth between Print Preview and Page Setup will make the process faster and easier.
Click on the "Page" tab and choose either portrait or landscape orientation. Changing the orientation to landscape may allow all the fields to print on the same page, thus eliminating the blank pages and saving your paper.
