20 Most Recent
HP Color LaserJet 5500 Printer Questions & Answers
59.9k error on hp laserjet 5500
59.9 error is caused by a problem with the ETB (transfer belt) motor. Check the connector that the belt plugs into to make sure it is not damaged. If you have a spare Transfer Belt I would try that first. Most likely the motor has failed and will require replacement.
12/13/2017 2:24:14 PM •
HP Color...
Answered
on Dec 13, 2017
I have an HP 5500 59.3K Printer Error
Unplug the printer from the power wait about 10 seconds and plug it back in. Turn the printer on and see if the error comes back. If so, contact an HP representative.
1/16/2017 2:16:24 AM •
HP Color...
Answered
on Jan 16, 2017
Hp 5500 dn laser replacement
It's not all that hard to do. You can also swap the lasers between colors to troubleshoot. Lasers come out from the rear of the machine.
6/10/2016 12:54:46 PM •
HP Color...
Answered
on Jun 10, 2016
How do i fix RFU LOAD ERROR
RFU is a remote firmware upgrade. Usually that error will occur when somebody messes with the printer while the firmware is downloading. Try doing the upgrade again. If it works great. But personally, I don't think that it will work. You probably have to replace the formatter. C9661-69002 for a duplex model. and C9660-69011 for the simplex(non-duplex)printer.
3/22/2016 5:55:52 AM •
HP Color...
Answered
on Mar 22, 2016
Irecev error 0c00400000020c
Go to the HP support website and download the "HP print and scan doctor " for your model - very useful for troubleshooting
1/17/2016 9:25:40 AM •
HP Color...
Answered
on Jan 17, 2016
53.11.03 error dimm 2 bank
try to reload the firmware or new firmware by going to the hp.com website and downloading the firmware utility tool. if it does not work the formatter board needs to be replaced.
11/13/2013 8:34:49 AM •
HP Color...
Answered
on Nov 13, 2013
Black vertical line down the middle of my copies?
theres a good chance that excess toner or Rubber degredation is what is causing your Black line/band,The Manual feed tray Uses A feed roller and a Seperation Pad If toner has spilt on to the top of the manual feed Roller Housing theres a good chance it may be Seeping on to the print paper Via the Feed roller Instructions:-open tray One at the front of tray one is a Closed Hatch which can be opened Upwards using the finger release catches on either end. Once lifted upwards the Manual feed roller should be clearly Visible - Rotate the feed roller until you can see the blue lock plate ho;ding the fed roller in place, insert a flat blade screw driver an d twist gently until you hear the lock plate release , remove the feed roller. You should now see the Offending Seperation pad. Cleaning the Seperation pad should be done using a Rubber restoration Liquid and LintFree Cloth. Use the same on the Feed roller . refit roller to tray and close and lock the Blue plate .close down the Service Hatch and return to machine -You may need to run several pages through tray one before all tread marks Dissapear
9/13/2013 2:12:33 PM •
HP Color...
Answered
on Sep 13, 2013
